Not any more though.
I'll have a look tomorrow and get back to you.
go fasterdbm wrote:When the vehicle is cold (after standing overnight), if I exit a side street from stationary using Manual and around 1/3rd throttle the car will not shift to second when I pull the '+' paddle around 2,600 rpm.
Sometimes, when the car is warm, and I am in Manual the car will not upshift when I use the '+' lever under harder acceleration (maybe 4/5ths throttle). This is probably more like 2,800 to 3000 rpm.
Any suggestions gladly received!
If I leave the car in D and pull out more gently then it changes up around 2,400 so I don't think that's a factor in this case.Stoo. wrote:It may need a software update, I'll check the tpi number next week.
Although, when cold, it may not let you change up too soon so to reduce load on the box/engine at cold temps/low engine speeds..?
