Slow to change gear?
2.5 I5 20v TFSI - 335 bhp
Stoo.
Post by Stoo. » Thu Jul 26, 2012 10:48 pm
My home town. :D
Not any more though.
I'll have a look tomorrow and get back to you.
dbm
Re: Slow to change gear?
Post by dbm » Fri Jul 27, 2012 6:39 am
That would be much appreciated. Information is my friend, and makes a stealer nervous :D
Stoo.
Post by Stoo. » Fri Jul 27, 2012 3:08 pm
Right, I need to know the exact symptoms as there are a few TPIs regarding RS3 DSG...
dbm
Post by dbm » Fri Jul 27, 2012 3:35 pm
When the vehicle is cold (after standing overnight), if I exit a side street from stationary using Manual and around 1/3rd throttle the car will not shift to second when I pull the '+' paddle around 2,600 rpm.
Sometimes, when the car is warm, and I am in Manual the car will not upshift when I use the '+' lever under harder acceleration (maybe 4/5ths throttle). This is probably more like 2,800 to 3000 rpm.
Any suggestions gladly received!
Dave_Hedgehog
Post by Dave_Hedgehog » Fri Jul 27, 2012 10:58 pm
dbm wrote:When the vehicle is cold (after standing overnight), if I exit a side street from stationary using Manual and around 1/3rd throttle the car will not shift to second when I pull the '+' paddle around 2,600 rpm.
go faster :)
Stoo.
Post by Stoo. » Fri Jul 27, 2012 11:07 pm
It may need a software update, I'll check the tpi number next week.
Although, when cold, it may not let you change up too soon so to reduce load on the box/engine at cold temps/low engine speeds..?
dbm
Post by dbm » Fri Jul 27, 2012 11:30 pm
Stoo. wrote:It may need a software update, I'll check the tpi number next week.
If I leave the car in D and pull out more gently then it changes up around 2,400 so I don't think that's a factor in this case.
Stoo.
Post by Stoo. » Fri Jul 27, 2012 11:34 pm
What, a software update?
dbm
Post by dbm » Sat Jul 28, 2012 12:16 am
No, the engine temp.
P1RWM
Post by P1RWM » Fri Aug 03, 2012 6:17 pm
Trip to dealer produced no answers for me on this. How long should it take for gearbox to adapt ? In drive it's is super smooth but manual is jerky especially on downshifts, but not consistent so I can't put a finger on what gear and revs combination exactly. I would say it is most common when travelling at a constant speed so for example following another car, and changing down in preparation for an overtake
dbm
Post by dbm » Fri Aug 03, 2012 7:17 pm
Similar for me. The car went in but nothing could be isolated or reproduced. I'm a professional software tester so I'm quite good at spotting patterns of behaviour and contributing circumstances. It looked like the car was consistently struggling when cold, but that now seems to have gone.
The master-tech at my dealership though it could just be rough during the process of adaption; maybe he was right? The car has only had a stumble once in the last week and it wasn't under cold-start conditions.
I would suggest keeping an eye on the behaviour for the next couple of hundred miles and see if it gets better. At the end of the day, you have 60k miles or three years for it to be decided. My first DSG did fail and needed a new mechatronic control unit. The problem was very pronounced and consistent in that case. This is nowhere like that (for me).
