S4 H&R Suspension Adjustment
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
BlackShadow
Post by BlackShadow » Fri Jul 23, 2004 5:31 pm
I have H&R suspension fitted to my car. When QST fitted it, they lowered it 30 mm. Annoyed with the constant grouding out over speed bumps and ramps, I got the suspension spanners out last night and increased the height. I then took a series of measurements. I measured from the top of the wheel nut cover (standard avus wheels), where you can hook you metal tape measure in nicely, to the top of the wheel arch. The measurements are:
Passenger Side Front: 18.5 cm Driver's Side Front: 18.1cm
Passenger Side Rear 18.6 cm Driver's Side Rear: 18.2 cm
The problem is that I didn't take these measurements before I raised the suspension, so I don't know how much I've raised it (Note:1 cm on the suspension thread does not equal 1 cm in ride height). Could some kind soul with an S4, with standard suspension and standard wheels, please take these measurements for me, so I can have a benchmark to work with for future adjustment.
:nogarors4:
Silver S4 Saloon
MTM Stage 4 (385 bhp), Mov'it Front Brakes, RS4 Rear Brakes, H&R Coilovers, Tanoga Shortshifter.
Morpheous
Post by Morpheous » Sat Jul 24, 2004 12:47 am
Cant give you my figs tonight.
Should really measure the distance from the adjuster to the base of the thread, the wings may not be the same height.
Adjusting the NSF will affect the OSR etc.
Best option is to set it up with corner weight scales.
Druggie
Post by Druggie » Sat Jul 24, 2004 1:29 am
What ride height is the best compromise to avoid scrapping to car?
Tony
S4- Possession without prescription is illegal
2000 S4 Silver, currently stock
BlackShadow
Post by BlackShadow » Mon Jul 26, 2004 8:53 am
So what's NSF and OSR then? Not too sure if I'm measuring the right thing. If somebody will tell me the best thing to measure, and what the base settings on a standard S4, then I will use this as a basis for further adjustment
Druggie, I'm basically trying to find the best compromise to avoid scrapping the car at the moment. However, for you it will depend on the speed hump and ramp situation in Melbourne, with which I'm not familiar with. When I eventually get what suits me, I'll post a message.
Silver S4 Saloon
Dippy
Post by Dippy » Mon Jul 26, 2004 12:14 pm
I think Morpheus is right. Whenever I have measured ride height to the wings I get different figures on each corner. I assume this was because the ground was not perfectly level. However if the wings are also not equal...
2001 Silver S4 Avant
BlackShadow
Post by BlackShadow » Mon Jul 26, 2004 1:04 pm
OK, point taken on the wings and the ground. I can measure the the distance between the adjuster and the base of the thread as suggested but I want an accurate measure of ground clearance, as a 1 cm movement on the thread may not (and according to QST does not) equal a 1 cm movement in ride height. So I suppose my question is what is the ground clearance on a standard S4 and how is this measured?
Silver S4 Saloon
BlackShadow
Post by BlackShadow » Mon Jul 26, 2004 1:24 pm
Right, the techie US Audi sites list the ground clearance of the standard S4 as 3.5 in (90 mm). Is there any reason to suspect that this will be different in the UK? Also, how do you measure this? Is it just the lowest hanging point? The exhaust? I suppose it is really, as this is the thing that will catch.
Silver S4 Saloon
Nordschleife
Post by Nordschleife » Mon Jul 26, 2004 4:38 pm
The US spec S4s ride noticably higher than European S4s, if you park the two nose to nose one looks to be noticably higher off the ground than the other. I wonder what Aus got?
R+C
Dippy
Post by Dippy » Mon Jul 26, 2004 5:10 pm
XXXX mm
Druggie
Post by Druggie » Tue Jul 27, 2004 6:30 am
ill measure mine and post back
Tony
BlackShadow
Post by BlackShadow » Wed Jul 28, 2004 9:10 am
So given that the US S4s ride higher, what is the ground clearance on a standard UK S4?
Silver S4 Saloon
BlackShadow
Post by BlackShadow » Thu Jul 29, 2004 11:25 am
Nobody is interested in this question. You all find it really boring, don't you? You don't care about the height clearance on a Standard S4, do you? You are all interested in lowering your suspension and scrapping your exhausts. Nobody can be bothered to measure the ground clearance or look in an old S4 brochure for me
I'm going away to cry now. Nobody loves me. :cry:
Silver S4 Saloon
DavidT
Post by DavidT » Thu Jul 29, 2004 12:12 pm
Wow there boy, calm down.
My standard S4 wheel arch edge (highest point) to ground was 68cm front and 67cm rear.
After AmD had fitted H&R coilovers it reduced to 63cm front and 64cm rear.
I hope that helps.
David
BlackShadow
Post by BlackShadow » Thu Jul 29, 2004 3:42 pm
I feel more loved now.
Silver S4 Saloon
Dippy
Post by Dippy » Mon Aug 02, 2004 12:43 pm
BS, I used to be concerned about scraping my exhaust, but not any more. It sounds much worse than it really is.
Users browsing this forum: Majestic-12 [Bot] and 92 guests
