Passengers side electric switch trim removal???
amanda1
Post by amanda1 » Tue Jul 24, 2012 3:34 pm
Before I break anything........does this just pop out or is there more too it???
950 nm torque!
imacool
Re: Passengers side electric switch trim removal???
Post by imacool » Tue Jul 24, 2012 3:42 pm
amanda1 wrote:Before I break anything........does this just pop out or is there more too it???
What switch? I'll look in Work Shop manual, just tell me what switch do you want to remove (seat, window?).
current: Quartz Grey A6 C6 Avant 3.0 TDI Le Mans
prev:Daytona grey RS6 C5 Avant,Black BMW 320D Coupe (E92),Red Honda Accord 1.8
gingertoss
Post by gingertoss » Tue Jul 24, 2012 3:47 pm
If its the window switch then there is a hole on the underside of the arm rest under the switch. Use the biggest allen key you can get in the hole and push the switch out gently.
2003 RS6 Avant, non res Miltek, 3" catless dps, wagners, MRC air filters, 044 fuel pump, MRC custom remap, TCU remap, 566ps, 812nm, pss9 coilovers, hotchkis rollbars, Recaro CSs, 390mm front discs, hi-spec 4 pot rear calipers.
imacool
Post by imacool » Tue Jul 24, 2012 4:03 pm
It took me ages to move the images and convert them to be viewable here, hope you appreciate the effort...
Vehicles with hole on underside
– Insert screwdriver -3- in hole.
– Use screwdriver -3- to press retaining tab -2- in direction of arrow -A-.
– Take out window regulator switch unit -1- in direction of arrow -B-.
Vehicles with no hole on underside
– Mask door trim with adhesive tape -4-.
– Take out window regulator switch unit -1- in direction of arrow.
All vehicles:
Press retaining tab -2- and pull off connector -1-.
amanda1
Post by amanda1 » Tue Jul 24, 2012 4:12 pm
Yes sorry Tis the window switch.....it has been picked at by the bratzs but no one will admit to it aghhhhhh :bash:
950 nm torque!
imacool
Post by imacool » Tue Jul 24, 2012 4:15 pm
Check the underneath, there may be a hole, if not then the second picture applies.
Mind the work Shop manual is written for left hand drive vehicles...
amanda1
Post by amanda1 » Tue Jul 24, 2012 4:52 pm
Thank you so much for the piccies :) I have the hole so as soon as I feed the bratzs I will let you know how I get on!!!
950 nm torque!
R8GXR
Post by R8GXR » Tue Jul 24, 2012 5:01 pm
<beep>, thought mine were bad! keep an eye out for the vapour blasting pictures later.
imacool
Post by imacool » Tue Jul 24, 2012 5:28 pm
R8GXR wrote:<beep>, thought mine were bad! keep an eye out for the vapour blasting pictures later.
I can't wait...
amanda1
Post by amanda1 » Tue Jul 24, 2012 7:29 pm
Well that was painless enough .....except the old trim bit is now broken due to getting the window switch out but the new trim bit was only £7.54 ;) so happy days!!!
950 nm torque!
Post by Shoppinit » Tue Jul 24, 2012 9:21 pm
Rub the remaining rubber off the door handle and it will look great with the new switch. This is what I did. It looks factory.
rosssavage
Post by rosssavage » Wed Jul 25, 2012 11:49 am
I did my mirror switch cover the other day and it looks so much better now.
Also did what Shop said and rubbed off the rubbish rubber finish on the door handles, good advice
Users browsing this forum: Google [Bot] and 128 guests
