Oil leak, eek....
adsgreen
Re: Oil leak, eek....
Post by adsgreen » Sat May 12, 2012 9:48 am
Jubilee clips are great :)
I hate push on only fittings (they just feel wrong).
The great thing about an afternarket replacement would be that you could use aluminium fittings which means the corrosion problem simply goes away.
I would be interested in a purchase to preempt the problem.
irvind
Post by irvind » Sat May 12, 2012 10:20 am
I'm wondering if anybody's ever had a go at Audi about this from a safety perspective? Travelling down the M6 with oil on the brakes (without the driver's knowledge) isn't the safest way to travel!
irvind
Post by irvind » Tue May 15, 2012 4:54 pm
Doug says it needs a new oil cooler....
I rang Inchcape Warranty. Unsurprisingly enough, external oil leaks are not covered. What a surprise.
PJC
Post by PJC » Tue May 15, 2012 5:00 pm
Any chance of goodwill from the dealer, I have an Inchcape warranty too and wouldn't be best pleased if mine wasn't covered.
irvind
Post by irvind » Tue May 15, 2012 5:47 pm
I've emailed Audi CS.
The guy at Inchcape said "external oil leaks are not covered, sorry"
RSKiwi
Post by RSKiwi » Tue May 15, 2012 6:12 pm
irvind wrote:Doug says it needs a new oil cooler....
Sympathy post.
Soooo been there. :thumbsdown:
____________________
C5 RS6 Avant
Gone
MRC'd B7 RS4
B6 3.0 A4
C5 A6
Pug 405 NZ Touring Car
Toyota Landcruiser
Teutonic Tuner
Post by Teutonic Tuner » Tue May 15, 2012 10:55 pm
Does that mean the oil cooler has failed or were the oil cooler pipes seized to the cooler and couldn't be removed (common problem)?
If there's no luck with the warrenty theres one on ebay from Aberdeen Audi for £540, not sure what they normally cost:
http://www.ebay.co.uk/itm/Genuine-Audi- ... 3cc3a3587f
Sprint Blue B7 RS4 gone but not forgotten...
irvind
Post by irvind » Tue May 15, 2012 11:14 pm
Teutonic Tuner wrote: or were the oil cooler pipes seized to the cooler and couldn't be removed (common problem)?
I believe that's the issue....
Nicely spotted on ebay though, will check that one out!
RSKiwi
Oil leak, eek....
Post by RSKiwi » Wed May 16, 2012 7:30 am
If you are having MRC do the work I think £500ish is in the ball park of why they charge for a new cooler. I can confirm tonight and PM you if you like?
C5 RS6 Avant
Gone
MRC'd B7 RS4
B6 3.0 A4
C5 A6
Toyota Landcruiser
voyager162
Post by voyager162 » Thu May 17, 2012 2:43 pm
i had the same problem, seems to be common fault. new pipes are i think 350ish from audi but a bit of a pain to fit.
Users browsing this forum: Google Adsense [Bot] and 124 guests
