where is the cooling fan fuse s42 located?
Nederland
Post by Nederland » Tue Apr 10, 2012 9:30 pm
Any one knows the location for the cooling fan fuse s42?
preferably with a picture.
According to elsawin it should be located in the 8-way relay carrier behind the drivers storage comparment.
Here is a pic I took from my relay carrier
Black Edition Audi RS6 4B, C5. ABT Tuned.
Re: where is the cooling fan fuse s42 located?
Post by chunky79 » Wed Apr 11, 2012 6:50 am
Er, have you checked all those fuses to see if one has blown????
Post by Shoppinit » Wed Apr 11, 2012 8:05 am
According to elsawin it's one of those horizontal ones at the bottom right. Looks like you've got a fair bit of non-standard wiring there.
Nederland
Post by Nederland » Sat Apr 14, 2012 9:02 pm
Thanks.
None of the these are blown: Image
So guess it is the Coolant Fan Control Module (J293) that's faulty. :(
Post by Shoppinit » Sat Apr 14, 2012 9:36 pm
Don't tell us too much about your problem, will you?
bilko1
Post by bilko1 » Sat Apr 14, 2012 9:39 pm
I've had the coolant fan control module fault since i've had my car and there's nothing wrong with it, quite a common fault apparently when googling. I did post a picture up of it's location somewhere on here.
Post by Shoppinit » Sat Apr 14, 2012 9:52 pm
One of the control modules is built into the fanmotor, the other one is under the chassis member at the front of the car.
Nederland
Post by Nederland » Sat Apr 14, 2012 10:10 pm
Shoppinit wrote:Don't tell us too much about your problem, will you?
Should have guessed it by now :P
18068 - Coolant Fan Control 1: Short to Ground
P1660 - 002 - Lower Limit Exceeded - Intermittent
Checked all the wiring and fuses so only one item remains. :(
your pic bilko1:
Post by Shoppinit » Sat Apr 14, 2012 10:23 pm
You can use the Vagcom to test the fans using the output tests. Do they both come on and ramp up?
Nederland
Post by Nederland » Sat Apr 14, 2012 10:31 pm
Shoppinit wrote:You can use the vagcom to test the fans using the output tests. Do they both come on and ramp up?
Will test it tomorrow.
Will let you know the results.
Nederland
Post by Nederland » Sat Apr 14, 2012 10:51 pm
Just found this:
3-point relay and fuse carrier
Behind driver's storage compartment, at central carrier
8-point relay carrier
Behind storage compartment (item 3)
13-point relay and fuse carrier
Behind driver's storage compartment (item 1)
Micro-central electrics
At relay carrier, behind driver's storage compartment (item 2)
Fuse carrier
Behind left dash panel side cover
Could come in handy for later reference.
Nederland
Post by Nederland » Mon Apr 16, 2012 3:56 pm
Kaput!
It doesn't respond at all doing the output test.
A new/old one from ebay should do the trick.
Looking at it's position it's gonna be a tough job replacing it. :/
Users browsing this forum: Shoppinit, Steve2003rs6 and 334 guests
