Wheel Balancing
Wheel Balancing
Anyone got any recommendations for getting wheels balanced in SE london? I get a vibration at around 78mph.
I've already taken it to one local place that totally f****d it up and gave me chronic wheel shake at 60, so got it undone and took it elsewhere but it hasn't sorted it. But they also told me the front left is warped, but would just like another opinion from someone I trust really!
Re: Wheel Balancing
Just be wary of what tread you've left on your tyres... anything less than 4mm and its very very difficult to balance properly from the natural wear of the tyre.
Present:...
Past:
Past:
- Mr Footlong
Re: Wheel Balancing
I have buckled a god few alloys in my day, are you sure you haven't hit a nasty pothole, gone a bit too quickly over a speed hump etc? Done wheels on both of those before so it isn't far fetched at all and a total beatch to balance out if at all.
Current:
Gone:
Gone:
Re: Wheel Balancing
Try Elite in Rainham Essex.
http://www.elitedirect.com/
they are good for 4-wheel laser alignment, tyres etc.
Re: Wheel Balancing
I had this when I first got my car. Turned out to be the tracking, not balance. After having the toe-in adjusted, the ride was perfect again.
Re: Wheel Balancing
The roads are a nightmare for potholes around here so could have been, I haven't clobbered any particularly hard but then again I suppose you wouldn't have to...Mr Footlong wrote:I have buckled a god few alloys in my day, are you sure you haven't hit a nasty pothole, gone a bit too quickly over a speed hump etc? Done wheels on both of those before so it isn't far fetched at all and a total beatch to balance out if at all.
I had the tracking checked at the second place they said it was fine, although they mentioned that the wheel was warped but had balanced it out so I shouldn't feel anything. I don't like the idea of a buying a new wheel just at the moment!
Re: Wheel Balancing
I would be interested to know how you get on??
I have the same problem and have had a 4 wheel alignment and wheel balancing done and still get vibration around the same speed.
I assumed that I had one or more buckled font wheels which I will try to sort out next...
Re: Wheel Balancing
ive balancing my wheels twice in a row, because after the first time there was still vibration at +/- 100 km/h...
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Yellow Koni's
- Mr Footlong
Re: Wheel Balancing
This is my key concern about getting Bimotos, that that have a bit of a reputation for buckling easily??mavada wrote:ive balancing my wheels twice in a row, because after the first time there was still vibration at +/- 100 km/h...
I was going to go with 20" S8 alloys but based on the shat roads here and the fact that I drive it like I stole it quite a lot I am fearful of bottoming out all the time but I don;t want to get more forgiving 19" bimotos just to find that I make them egg shaped at the drop of a hat!
Current:
Gone:
Gone:
Re: Wheel Balancing
Get the forged ones then. Much stronger.
Re: Wheel Balancing
It wasnt with the Bimotos, it was with the 18 inch originals...by Mr Footlong » 24 Jan, 2012 - 14:14
Bimotos are still going strong without vibrations...
Yellow Koni's
Yellow Koni's
Re: Wheel Balancing
While very happy with the Bimotos, probably getting these in the future...(although the comfort will be dramatically worse, ive noticed already going from 18 to 19 inch...)
Yellow Koni's
Yellow Koni's
- Mr Footlong
Re: Wheel Balancing
This is one of my fears too! I am finding the current height/firmness of the PSS9s to be too much so they will be getting raised/softened at some point. Without slapping on the S* ones and trying them I just don't know and I can't afford 4 figure gambles right now.mavada wrote:although the comfort will be dramatically worse, ive noticed already going from 18 to 19 inch...
Current:
Gone:
Gone:
Re: Wheel Balancing
the only downside (if you can call it a downside) is the width of the s8 rims, currently im running 275 which looks great...
Yellow Koni's
Yellow Koni's
Re: Wheel Balancing
I'm on H&R's with 19's. It looks great but it's a damn hard ride. Am I right in saying the H&R's are adjustable?
Users browsing this forum: No registered users and 149 guests
