Key coding
rs6mick
Key coding
Post by rs6mick » Fri Dec 09, 2011 12:44 pm
Hi people need help with coding a new key I have been told that I can do this with my Vagcom but not sure if it's true or if anyone has done this I'm needing a lot of help lately as you can tell with all my last topics thanks
marv8
Re: Key coding
Post by marv8 » Fri Dec 09, 2011 1:58 pm
http://www.ross-tech.com/vag-com/cars/key-matching.html
Try here ^ also read about a way you can do it without vcds but never tried it - was listed in the bentley manual from memory
MEV
Re: Key coding
Post by MEV » Fri Dec 09, 2011 2:00 pm
Well Im not sure you can do it Vagcom but Im sure someone will pipe up on that. If it helps I have ordered one from Timpsons ( cobblers key cutters etc) I have to take the car in tomorrow where he codes it for me. Total cost is around £150 minus also a 15% voucher on line. so in all about 60 odd quid at least cheaper than Audi.
B7 RS4 - 07 Phantom, Silver leather, 59k. Current
B5 RS4 - 01 Avus, B7 Brake kit, Miltek cat back, Sroof, leather, optics. 66k. Current
B8 RS4 - Sepang, BO, Roof, Sports Sold
C5 RS6 + # 296 Ebony black, full optics, titans, carbon and natural leather - sold and missed
B7 RS4 Avant Daytona Pearl, black optics, SS+, buckets, privacy. Sold
B5 RS4 - MRC 420. Gone but not forgotten.
Maximo
Re: Key coding
Post by Maximo » Fri Dec 09, 2011 2:13 pm
Where in the world are you, it sounds like you need some assistance to help you along. I'm sure there is a friendly fellow near you that can help explain the joy's of using Vagcom. If your anywhere near me I'd more then happy to help.
R18 GTX Estate > Saphire 2.0i Ghia > R19 16v > Vectra V6 SRi > M3 > RS6 Avant
Re: Key coding
Post by Shoppinit » Fri Dec 09, 2011 2:32 pm
You can do it with the Vagcom if you have the SKC which you won't have. For our immobilisers the SKC code is a rolling encryption and the dealership request the code from Audi in Germany and it will be valid only on that day. Audi will charge you £50 to code the key.
bakustax
Re: Key coding
Post by bakustax » Fri Dec 09, 2011 2:57 pm
I'm not sure if this will work but certainly worth a try...when you change the battery in the key you have to go thru a bit of a faff to get it to "code" the key.
This involves inserting the key into the ignition and turning two clicks round and pressing the lock/unlock button 3 times before the key will work again normally.
As I say it might not work for a previously un coded key...but worth a try before Audi relieve you of £50 for one of their techs to do the same.
Re: Key coding
Post by Shoppinit » Fri Dec 09, 2011 3:00 pm
That's for the remote. Will have no effect on the coding of the key. The remote is easy to match to the car and no special tools are necessary.
bakustax
Re: Key coding
Post by bakustax » Fri Dec 09, 2011 3:12 pm
Ah okay...just chipped in cause I have heard of Audi charging around £80 in Aberdeen for a battery change and "recode"...Aberdeen gypes with more money than sense.
Re: Key coding
Post by Shoppinit » Fri Dec 09, 2011 5:57 pm
That's shocking. Especially since the procedure for matching the remote is in the handbook.
bilko1
Re: Key coding
Post by bilko1 » Sat Dec 10, 2011 11:21 pm
Shoppinit wrote:You can do it with the vagcom if you have the SKC which you won't have. For our immobilisers the SKC code is a rolling encryption and the dealership request the code from Audi in Germany and it will be valid only on that day. Audi will charge you £50 to code the key.
Is the SKC the number on the black plastic tab attached to the keys when new. ? Also i thought you could use a certain device to get the SKC.
Re: Key coding
Post by Shoppinit » Sun Dec 11, 2011 9:24 am
No, you never have the SKC code.
Will340
Re: Key coding
Post by Will340 » Fri Jan 13, 2012 12:47 pm
MEV wrote:Well Im not sure you can do it VAGcom but Im sure someone will pipe up on that. If it helps I have ordered one from Timpsons ( cobblers key cutters etc) I have to take the car in tomorrow where he codes it for me. Total cost is around £150 minus also a 15% voucher on line. so in all about 60 odd quid at least cheaper than Audi.
I've just had one done, bought a blank key off ebay £45:
http://www.ebay.co.uk/itm/180750153820? ... 1497.l2649
Had it cut at Sainsburys whilst shopping £2
Had it coded at South Hereford Audi £50 including wash and vac, cup of tea and two biscuits whilst I poked around the shiny R8s mmmmm maybe one day!
http://www.south-hereford.audi.co.uk
