Key coding
Key coding
Hi people need help with coding a new key I have been told that I can do this with my Vagcom but not sure if it's true or if anyone has done this I'm needing a lot of help lately as you can tell with all my last topics thanks
Re: Key coding
http://www.ross-tech.com/vag-com/cars/key-matching.html
Try here ^ also read about a way you can do it without vcds but never tried it - was listed in the bentley manual from memory
Re: Key coding
Well Im not sure you can do it Vagcom but Im sure someone will pipe up on that. If it helps I have ordered one from Timpsons ( cobblers key cutters etc) I have to take the car in tomorrow where he codes it for me. Total cost is around £150 minus also a 15% voucher on line. so in all about 60 odd quid at least cheaper than Audi.
B7 RS4 - 07 Phantom, Silver leather, 59k. Current
B5 RS4 - 01 Avus, B7 Brake kit, Miltek cat back, Sroof, leather, optics. 66k. Current
B8 RS4 - Sepang, BO, Roof, Sports Sold
C5 RS6 + # 296 Ebony black, full optics, titans, carbon and natural leather - sold and missed
B7 RS4 Avant Daytona Pearl, black optics, SS+, buckets, privacy. Sold
B5 RS4 - MRC 420. Gone but not forgotten.
Re: Key coding
Where in the world are you, it sounds like you need some assistance to help you along. I'm sure there is a friendly fellow near you that can help explain the joy's of using Vagcom. If your anywhere near me I'd more then happy to help.
R18 GTX Estate > Saphire 2.0i Ghia > R19 16v > Vectra V6 SRi > M3 > RS6 Avant
Re: Key coding
You can do it with the Vagcom if you have the SKC which you won't have. For our immobilisers the SKC code is a rolling encryption and the dealership request the code from Audi in Germany and it will be valid only on that day. Audi will charge you £50 to code the key.
Re: Key coding
I'm not sure if this will work but certainly worth a try...when you change the battery in the key you have to go thru a bit of a faff to get it to "code" the key.
This involves inserting the key into the ignition and turning two clicks round and pressing the lock/unlock button 3 times before the key will work again normally.
As I say it might not work for a previously un coded key...but worth a try before Audi relieve you of £50 for one of their techs to do the same.
Re: Key coding
That's for the remote. Will have no effect on the coding of the key. The remote is easy to match to the car and no special tools are necessary.
Re: Key coding
Ah okay...just chipped in cause I have heard of Audi charging around £80 in Aberdeen for a battery change and "recode"...Aberdeen gypes with more money than sense.
Re: Key coding
That's shocking. Especially since the procedure for matching the remote is in the handbook.
Re: Key coding
Is the SKC the number on the black plastic tab attached to the keys when new. ? Also i thought you could use a certain device to get the SKC.Shoppinit wrote:You can do it with the vagcom if you have the SKC which you won't have. For our immobilisers the SKC code is a rolling encryption and the dealership request the code from Audi in Germany and it will be valid only on that day. Audi will charge you £50 to code the key.
Re: Key coding
No, you never have the SKC code.
Re: Key coding
MEV wrote:Well Im not sure you can do it VAGcom but Im sure someone will pipe up on that. If it helps I have ordered one from Timpsons ( cobblers key cutters etc) I have to take the car in tomorrow where he codes it for me. Total cost is around £150 minus also a 15% voucher on line. so in all about 60 odd quid at least cheaper than Audi.
I've just had one done, bought a blank key off ebay £45:
http://www.ebay.co.uk/itm/180750153820? ... 1497.l2649
Had it cut at Sainsburys whilst shopping £2
Had it coded at South Hereford Audi £50 including wash and vac, cup of tea and two biscuits whilst I poked around the shiny R8s mmmmm maybe one day!
http://www.south-hereford.audi.co.uk
