...noticed an irregularity in the brake pedal under very heavy braking. It feels like a clicking / crunching through the pedal which occurs after the brakes have been used gently for a while and then hard pressure is applied. It happens only when in motion, not stationary and is definately not the ABS.
This was something I noticed with the OEM brakes plus green stuff pads, and thought the pad design may not be perfect and movement may have caused the feel. However, with the Stoptech brake kit fitted the same crunch / click can be felt at times.
I have looked over the brake system myself and got Brian @ star performance to wave his spanners at it, but we can find nothing obvious. Do they all do it? Any suggesstions? Worn suspension bushes??
Cheers!
David
Has anyone else...
Yes, but if the ABS only pulses a couple of times before traction is regained, maybe the result is as you (and I) have experienced?
2001 Silver S4 Avant
Users browsing this forum: No registered users and 172 guests
