sideways
Re: sideways
Post by chunky79 » Thu Dec 01, 2011 6:57 am
Well, got the assymetric 2's on now. Took the knobbly bit down yesterday and boy do the tyres get close to the suspension arm. I had never noticed it before so another big thumbs up to this forum. Got to remember to sort out my tyre pressures out now.
mavada
Re: sideways
Post by mavada » Thu Dec 01, 2011 9:31 am
by chunky79 » 01 Dec, 2011 - 05:57
Got to remember to sort out my Tyre pressures out now.
Im still sorting out my pressure, ive already lowered it from 50 psi (3,5 bar) to 43 psi (3 bar) but i find them still too bouncy/hard...
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Re: sideways
Post by Shoppinit » Thu Dec 01, 2011 9:44 am
How can you tell if your DRC is knackered?
Re: sideways
Post by bam_bam » Thu Dec 01, 2011 10:11 am
50 psi :shock:
I run 38 if I know I'm going on a spirited run and 40-42 every other day (depending on the ambient).
Daveperc
Re: sideways
Post by Daveperc » Thu Dec 01, 2011 10:12 am
I think most of us run around 40psi on most of the tyres, otherwise it's just too hard.
If DRC is knackered you'll get, clonking noises over bumps, especially when the system is cold, and uneven handling. Inspection will show traces of hydraulic on the dampers
Dave
Mr Footlong
Re: sideways
Post by Mr Footlong » Thu Dec 01, 2011 10:17 am
I am running 36 all round on the little 18's. Would be too hard/rattly otherwise for me on the DRC.
Current:
Gone:
Re: sideways
Post by Shoppinit » Thu Dec 01, 2011 10:18 am
Daveperc wrote:If DRC is knackered you'll get, clonking noises over bumps, especially when the system is cold, and uneven handling. Inspection will show traces of hydraulic on the dampers
Mine didn't. No oil traces, no clonking, no noises of any kind. However, over small bumps it was unpleasant. A bit like as if my tyres were too hard...
mavada
Re: sideways
Post by mavada » Thu Dec 01, 2011 12:50 pm
by bam_bam » 01 Dec, 2011 - 09:11
I thought if youre driving at high speeds often, you'll have to have more psi in the tyres...
Yellow Koni's
mavada
Re: sideways
Post by mavada » Thu Dec 01, 2011 3:13 pm
Off topic...
I remember my knocking noise from the right front side was gone after some hours on a ramp....but came back within a day...
Yellow Koni's
Re: sideways
Post by chunky79 » Fri Dec 02, 2011 5:36 pm
His tyres will have bloody flat spots soon.
Re: sideways
Post by bam_bam » Fri Dec 02, 2011 6:08 pm
They get hot, therefore start at 38 with a 5psi uplift on heat. Not a lot different to track driving, unless you're using nitrogen.
Users browsing this forum: No registered users and 222 guests
