So whos had enough of there SATNAV
Re: So whos had enough of there SATNAV
Odd- I find the rns-e optimistic. What year map?
- PetrolDave
Always been the same from 2005 through to 2011 maps.adsgreen wrote:Odd- I find the rns-e optimistic. What year map?
The only issue I had was the audio announcements once on a roundabout were wrong about 20% of the time. All diagrams and approach instructions work fine but once on the roundabout it says "take the 2nd exit" instead of "next exit". Basically the timing is flawed. They did realise a s/w update that's solved most 3G users problems but there's a number of us where it's not solved.PetrolDave wrote:(Scotty on tyresmoke has been in "discussions" with Audi for some time over the problems with his).
Since my car's 2 years 2 months old and is now only approaching 10k miles (usage dropped once we'd bought it) then it's not a major thing.... but it should work and it doesn't.
Now the face lifted A4 is coming with a new Nav there's no chance of them fixing it hence me takign £1k in compensation. It should work but I'd settle for the fault and £1000 if given the choice anyway.
B8 A4 Avant quattro
Honda CBR1100XX Super Blackbird
Suzuki GSXR1000 (Track bike)
B6 S4 (AMD Stage 3) - GONE
8N TT (APR/AMD/MTM) - GONE
i love how it says '' prepare to arrive at the roundabout'' lol, what should i be doing? looking in the glovebox, checking the rear ashtray?
- captain_stealth
Can anyone confirm if there's going to be a 2012 DVD and if so, when it is likely to come out?
2011 is the last one i believe
- PetrolDave
Audi will almost certainly keep issuing new DVDs at least until they stop selling new cars using the RNS-E, and since the 8P A3, 8J TT & the R8 (which all use the RNS-E) are still in production I very much doubt that 2011 will be the last one.Rick_RS4 wrote:2011 is the last one i believe
ah right, i thought i read that 2011 was the last one they were going to release due to them not making the rnse anymore?PetrolDave wrote:Audi will almost certainly keep issuing new DVDs at least until they stop selling new cars using the RNS-E, and since the 8P A3, 8J TT & the R8 (which all use the RNS-E) are still in production I very much doubt that 2011 will be the last one.Rick_RS4 wrote:2011 is the last one i believe
i need to get an updated disk really
- PetrolDave
They're very definitely still making the RNS-E, you'll hear people refering to the pre-2010 RNS-E (as is fitted to the RS4) and the 2010+ RNS-E (which has a higher resolution screen and works with SDHC cards), both use the same maps.Rick_RS4 wrote:i thought i read that 2011 was the last one they were going to release due to them not making the rnse anymore?
PetrolDave wrote:They're very definitely still making the RNS-E, you'll hear people refering to the pre-2010 RNS-E (as is fitted to the RS4) and the 2010+ RNS-E (which has a higher resolution screen and works with SDHC cards), both use the same maps.Rick_RS4 wrote:i thought i read that 2011 was the last one they were going to release due to them not making the rnse anymore?
ah great, thought it would be redundant, could the newer one be retrofitted? our units work with SD cards, do you mean for films?
wouldnt mind fitting a reversing camera and bluetooth to mine but unsure what to get
My mates got a reverse camera on his '09 Golf GTi. He only uses it to oggle birds when they walk past.Rick_RS4 wrote:PetrolDave wrote:They're very definitely still making the RNS-E, you'll hear people refering to the pre-2010 RNS-E (as is fitted to the RS4) and the 2010+ RNS-E (which has a higher resolution screen and works with SDHC cards), both use the same maps.Rick_RS4 wrote:i thought i read that 2011 was the last one they were going to release due to them not making the rnse anymore?
I hate the NAV. The voice is naff, it repeats instructions too often and sends me on the weirdest routes.
Shame they can't get a Tomtom unit permanently fixed.
Shane
Current
2017 C7 Nardo RS6 Performance
Gone:
C43 AMG Coupe
Black E92 M3
Daytona B7 RS4 Saloon
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Cavalier 1.8 lsi
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
- PetrolDave
Yes, I've got a 2010+ RNS-E in my RS4, BUT you have to find a spare A4 faceplate (or swap the one on your existing RNS-E) and fit it yourself as the newer one isn't available in A4 form.Rick_RS4 wrote:ah great, thought it would be redundant, could the newer one be retrofitted?
No, the SD (SDHC) cards are for Mp3 files ONLY.Rick_RS4 wrote:our units work with SD cards, do you mean for films?
Try looking on audiforum.us, several people have fitted the reversing camera using the Audi camera and a Kufatec IMA Plus multimedia adapter.Rick_RS4 wrote:wouldnt mind fitting a reversing camera and bluetooth to mine but unsure what to get
Bluetooth is an easy retrofit (takes about 1 1/2 hours) using the harness from Kufatec to fit the OE module behind the glovebox.
thanks ill take a look
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 332 guests
