moody warning lights....
Re: moody warning lights....
Have you checked your fluid level. What are you getting lighting up? The warning lights as in your photo? Or the brake warning symbol in the DIS?
@Spitelli: extremely common.
the yellow circle with broken lines either side..worn front pad symbol in the DIS.It cant be the pads..if it is, i`ll be spitting feathers with the garage.
She may be big and heavy but its whats on the inside that counts.....
What is the average lifespan for a set of pads..
Depends how you drive the car and what pads you are using. If you take it to the ring then 1 day.
Shoppinit wrote:Have you checked your fluid level?
I am assuming u mean brake fluid..would that throw a yellow light..i neeto get vagcom ..i am assuming its a download and a connector cable..is it worth getting the pro pack.Shoppinit wrote:Shoppinit wrote:Have you checked your fluid level?
Or you could just open the lid and peek inside...
Lol..i wasn't referring to how to check the level but in general..the connection to a state of relaxation with this car is tenuous as u said.Shoppinit wrote:Or you could just open the lid and peek inside...
For crying out loud..ignition checks now give me a yellow ok..levels between min and max..lots of steam coming out the reservoir though..my head is getting done in by this audit ownership experience..it certainly is like a moody bird.
- posterboyj
cfcdoc, as said above you'll need a diagnostic scan to find out what the issue is. Just be patient and you'll get through
Cornishmoocher wrote:Buying an RS6 and then worrying about the fuel consumption is a bit like buying a boat and worrying about getting it wet.
posterboyj wrote:cfcdoc, as said above you'll need a diagnostic scan to find out what the issue is. Just be patient and you'll get through
Thanks mate..love the car truly, madly, deeply..the baggage is the killer.
- posterboyj
Had a similar issue, turned out to be the longitudinal sensor which is £150.
Unfortunately the yaw sensor has the same symptoms and the sensor is £600~
Where are you cfdoc ? I'm in dorset and have genuine VCDS.
Southampton mate, many thanks for the offer but will really need a copy myself (for my own sanity if anything) Quick question though..is it a unit or a program. What exactly do I buy? Cable + the program (is it downloadable). Reason I ask is my old man has a new s3 and would he or I be able to install it on his laptop aswell if its not a tangible unit as such.bilko1 wrote:Where are you cfdoc ? I'm in dorset and have genuine VCDS.
It's a cable that contains the key for the software. So the software is freely downloadable, but won't work without a genuine cable. So you can install it on as many computers as you like, but you'll need the cable to connect to the car.
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 144 guests
