moody warning lights....
Re: moody warning lights....
Post by Shoppinit » Sat Oct 22, 2011 3:16 pm
Have you checked your fluid level. What are you getting lighting up? The warning lights as in your photo? Or the brake warning symbol in the DIS?
@Spitelli: extremely common.
cfcdoc
Post by cfcdoc » Sat Oct 22, 2011 3:21 pm
the yellow circle with broken lines either side..worn front pad symbol in the DIS.It cant be the pads..if it is, i`ll be spitting feathers with the garage.
She may be big and heavy but its whats on the inside that counts.....
cfcdoc
Post by cfcdoc » Sat Oct 22, 2011 4:14 pm
What is the average lifespan for a set of pads..
Post by Shoppinit » Sat Oct 22, 2011 4:20 pm
Depends how you drive the car and what pads you are using. If you take it to the ring then 1 day.
Post by Shoppinit » Sat Oct 22, 2011 4:21 pm
Shoppinit wrote:Have you checked your fluid level?
cfcdoc
Post by cfcdoc » Sat Oct 22, 2011 4:39 pm
I am assuming u mean brake fluid..would that throw a yellow light..i neeto get vagcom ..i am assuming its a download and a connector cable..is it worth getting the pro pack.
Post by Shoppinit » Sat Oct 22, 2011 4:46 pm
Or you could just open the lid and peek inside...
cfcdoc
Post by cfcdoc » Sat Oct 22, 2011 4:52 pm
Shoppinit wrote:Or you could just open the lid and peek inside...
Lol..i wasn't referring to how to check the level but in general..the connection to a state of relaxation with this car is tenuous as u said.
cfcdoc
Post by cfcdoc » Sat Oct 22, 2011 6:06 pm
For crying out loud..ignition checks now give me a yellow ok..levels between min and max..lots of steam coming out the reservoir though..my head is getting done in by this audit ownership experience..it certainly is like a moody bird.
posterboyj
Post by posterboyj » Sat Oct 22, 2011 7:45 pm
cfcdoc, as said above you'll need a diagnostic scan to find out what the issue is. Just be patient and you'll get through
Cornishmoocher wrote:Buying an RS6 and then worrying about the fuel consumption is a bit like buying a boat and worrying about getting it wet.
cfcdoc
Post by cfcdoc » Sat Oct 22, 2011 7:55 pm
posterboyj wrote:cfcdoc, as said above you'll need a diagnostic scan to find out what the issue is. Just be patient and you'll get through
Thanks mate..love the car truly, madly, deeply..the baggage is the killer.
posterboyj
Post by posterboyj » Sat Oct 22, 2011 9:40 pm
Had a similar issue, turned out to be the longitudinal sensor which is £150.
Unfortunately the yaw sensor has the same symptoms and the sensor is £600~
bilko1
Post by bilko1 » Sat Oct 22, 2011 11:37 pm
Where are you cfdoc ? I'm in dorset and have genuine VCDS.
cfcdoc
Post by cfcdoc » Sun Oct 23, 2011 10:17 am
bilko1 wrote:Where are you cfdoc ? I'm in dorset and have genuine VCDS.
Southampton mate, many thanks for the offer but will really need a copy myself (for my own sanity if anything) Quick question though..is it a unit or a program. What exactly do I buy? Cable + the program (is it downloadable). Reason I ask is my old man has a new s3 and would he or I be able to install it on his laptop aswell if its not a tangible unit as such.
Post by Shoppinit » Sun Oct 23, 2011 10:24 am
It's a cable that contains the key for the software. So the software is freely downloadable, but won't work without a genuine cable. So you can install it on as many computers as you like, but you'll need the cable to connect to the car.
Users browsing this forum: No registered users and 115 guests
