Rear LED lamps for B7 in this months Audi Driver mag?
lengster1
Post by lengster1 » Wed Aug 04, 2010 11:55 am
Sorry for late entry into this thread but do they do any that run the reverse C shape leds as dytime running lights the same as on brand new golfs?
P_G
Post by P_G » Wed Aug 04, 2010 12:58 pm
I think that may be style one, similar to to that ion the Mk II TT?
mark758
Post by mark758 » Wed Aug 04, 2010 11:15 pm
LEDs look superb Wellzie :-)
2013 Ibis White RS7¬
¦ParkingPackPlus¦Sunroof¦HUD¦AudiConnect¦HeatedRearSeats¦RearSideAirbags¦RedBrakeCalipers¦QuattroPuddelights¦SoftCloseDoors¦NightVision¦Dynamic Package¦CarbonPackage¦CarbonMirrors¦21" GlossBlack¦ACC¦Stop&Go¦PreSensePlus¦SideAssist¦LaneAssist¦B&O¦BlackOptics¦OEMBlackBadging¦Gyeon Q2 Duraflex¦
seventeenAPG
Post by seventeenAPG » Thu Aug 05, 2010 9:00 am
mark758 wrote:LEDs look superb Wellzie :-)
+1
seventeenAPG
Post by seventeenAPG » Sun Aug 29, 2010 11:03 am
17-APG wrote:
wellzieRS4 wrote:
17-APG wrote: I'm getting a set of LED bulbs for indicators that light up orange for my orinigal LEDs that I bought from BM. Will let you know how it works when I get them. :thumbs:
Didnt know you could get them look foward to it where did you buy the orange leds, BMTown?
Yes, BM are sourcing for me and also the DRLs . Hope to have both indicator bulbs and DRLs in a few weeks to try out. Nice to have bright white lights for the DRLs!!! Will update as soon as...
Well, got the rear indicator bullbs as well as number plate bulbs but didnt work out too well... The indicator bulbs flash too fast as if there is a bulb failure and the bulb out warning comes on. Same with the rear number plate bulbs. When I have fitted both bulbs they pulsate between "bright and then"not as bright" if you know what I mean. Now, if I take out one of the bulbs and replace with the original then the remaining LED works fine. I am beginning to think that there might be something wrong with my car. I say this because BM Town kindly replaced my main rear LED units because sometimes when I start the car the driver side brake light and the passenger side fog light unit do not operate. In conjunction with this I get bulb out warnings. Later they come on. Now the exact same thing is happening with the replacement units that BM sent to me. Does anyone know what might be up with my wiring??
wellzieRS4
Post by wellzieRS4 » Sun Aug 29, 2010 12:34 pm
17-APG wrote:
17-APG wrote:
wellzieRS4 wrote: Didnt know you could get them look foward to it where did you buy the orange leds, BMTown?
This has happened to me once
MB2
Post by MB2 » Sun Aug 29, 2010 1:00 pm
I had bulb out warnings with number plate lights that were meant to work OK so had to send them back. Some I saw on a US site said only work with red DIS so I think colour DIS is very sensitive
PetrolDave
Post by PetrolDave » Sun Aug 29, 2010 6:32 pm
MB2 wrote:Some I saw on a US site said only work with red DIS so I think colour DIS is very sensitive
The red DIS is normally only fitted with the lowline spec which doesn't have bulb failure monitoring.
seventeenAPG
Post by seventeenAPG » Wed Sep 01, 2010 8:48 am
wellzieRS4 wrote:
17-APG wrote:
17-APG wrote: Yes, BM are sourcing for me and also the DRLs . Hope to have both indicator bulbs and DRLs in a few weeks to try out. Nice to have bright white lights for the DRLs!!! Will update as soon as...
Did it happen the exact same way in the one brake light and one fog light failed to come on?
I am going to do a few tests over the next few days to see if I can narrow the issue down.
seventeenAPG
Post by seventeenAPG » Wed Sep 01, 2010 12:53 pm
MB2 wrote:I had bulb out warnings with number plate lights that were meant to work OK so had to send them back. Some I saw on a US site said only work with red DIS so I think colour DIS is very sensitive
Same here. When fitted they seemed to "pulse" between a bright light and then dimmer. I took them out and refitted but still the same. Bulb out warning also. So I guess there is no way round this one??
seventeenAPG
Post by seventeenAPG » Tue Sep 07, 2010 5:57 pm
I am replying here cause I hope PetrolDave can help!!! Symptom, my BM Town leds activate bulb out when I start the car at night. The driver side brake light does not come on nor the passenger side fog light. Its really weird that these are the specific two. BM kindly replaced them a few weeks back for the same reason. The new ones are the same. So, I tried a few configurations of DRLs on/off and get me home lights on/off. The culprit is the get me home lights. If I keep them permanently turned off I do not get bulb out warnings. Should say here also there are no warnings in daylight hours with both DRL and get me home on. It just seems to happen when I start the car at night. When I unlock the car the get me home lights up. At this time all rear LEDs light up ok. Then, when I start the car, the two rear one go out and bulb out occurs. Any ideas PetrolDave on what might be going on here??
PetrolDave
Post by PetrolDave » Tue Sep 07, 2010 7:00 pm
17-APG wrote: I am replying here cause I hope PetrolDave can help!!! Symptom, my BM Town leds activate bulb out when I start the car at night. The driver side brake light does not come on nor the passenger side fog light. Its really weird that these are the specific two. BM kindly replaced them a few weeks back for the same reason. The new ones are the same. So, I tried a few configurations of DRLs on/off and get me home lights on/off. The culprit is the get me home lights. If I keep them permanently turned off I do not get bulb out warnings. Should say here also there are no warnings in daylight hours with both DRL and get me home on. It just seems to happen when I start the car at night. When I unlock the car the get me home lights up. At this time all rear LEDs light up ok. Then, when I start the car, the two rear one go out and bulb out occurs. Any ideas PetrolDave on what might be going on here??
The get me home lights only come on after dark, so that's why you don't get bulb failure warnings in daylight.
I wonder if it's the voltage difference between engine off and engine running that causes the problem. Maybe the rear LEDs don't increase their current draw as much as the bulb failure warning system is expecting when you start the car, and that triggers the bulb failure warning?
seventeenAPG
Post by seventeenAPG » Tue Sep 07, 2010 8:56 pm
Thats right, they come on in dark conditions only and that's when I get the warning. It could be due to voltage issues because the rear lights are already lit in this situation when the car is started. Funny thing is why doesn't everyone have this issue?
neilfergusonuk
Re: Rear LED lamps for B7 in this months Audi Driver mag?
Post by neilfergusonuk » Fri Sep 16, 2011 1:52 am
Some helpful info on here!
Give me the Traction and I'll spin the world!
Users browsing this forum: No registered users and 120 guests
