Tyre Pressures for 225/40 ZR18 tyres ???
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Nige_RS4
Post by Nige_RS4 » Mon Mar 22, 2004 2:48 pm
Any recommendations for fast road (not track-days)? I'm running 32psi all-round at the moment and am feeling every pimple in the road. Anyone got any experiences ?
jeffw
Post by jeffw » Mon Mar 22, 2004 4:27 pm
I would think that is a little low....normally I would run 34-36 psi
Nige_RS4
Post by Nige_RS4 » Mon Mar 22, 2004 4:43 pm
Thanks Jeff, surely that would make the ride even more firm?
jeffw
Post by jeffw » Mon Mar 22, 2004 6:29 pm
Yes but that's a product of your suspension ...you could try less pressure but you may find that you get some strange wear and/or overheating of the tyre. Sounds like you need adjustable suspension.
BRETTCOLLINS
Post by BRETTCOLLINS » Tue Mar 23, 2004 9:09 am
I have 225/40ZR18 on my S4 with H&R coil overs. running 34 psi at the rear 36 psi at the front. with Uniroyal rainsport tyres.
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
DavidT
Post by DavidT » Tue Mar 23, 2004 11:57 am
I have 235/40/17's and run 38 all round and it's spot on.
Any less and I find the steering goes 'Audi'
AFAP18
Tire pressure
Post by AFAP18 » Tue Mar 23, 2004 8:19 pm
In the city, I run 30-32, due to bad pavement.
When taking the car to the outside the city, usually run 36.. I am pretty satisfied with those numbers.
Don´t know about track, my guess is that the should run about 40.
By the way I run Stock wheels with Bilstein shocks and H&R springs, with ECS "coilover" kit.
Audi Freak
__________________________
Audi S4 Avant 2000 -6spd - silver -
DavidT
Post by DavidT » Tue Mar 23, 2004 9:13 pm
Nige_S4 wrote:Thanks Jeff, surely that would make the ride even more firm?
It could actually improve the ride by making the sidewall taller.
The lower the profile the stiffer the sidewall and the higher the sensitivity to the inflation pressure.
Good luck :wink:
robscim
Post by robscim » Thu Mar 25, 2004 11:31 pm
I'm running the same size tyres as you with lowered H&R coilovers. I run 38 all round and will increase by about 4 lbs for the loaded charge to Le Mans. :biggrin3:
At 38, the right is excellent. Really very comfortable given the handling.
What brand of tyres are you using?
Rob
:yellowrs4:
Users browsing this forum: No registered users and 125 guests
