Replacing trim which inc badge on flat bottom steering wheel
JZARS
Post by JZARS » Wed Aug 03, 2011 7:07 pm
I have tried the search function with no luck!
I have a new trim which includes the RS4 badge, to go onto my flat bottom steering wheel. I have unscrewed the 4 star drive screws but it wont budge. Has anyone else managed to do this please? If so please can you let me know how!
Thanks in advance!!
adsgreen
Re: Replacing trim which inc badge on flat bottom steering w
Post by adsgreen » Wed Aug 03, 2011 7:07 pm
iirc the 4 screws should be it. it may have some glue so see if you can gently tease it apart.
Rick_RS4
Post by Rick_RS4 » Wed Aug 03, 2011 7:47 pm
its a right pain in the ass, start to pull one side towards you then wiggle it off, pull hard like your going to pull the wheel off, its not glue as such its=ts just a really tight fit
JZARS
Post by JZARS » Wed Aug 03, 2011 7:49 pm
thank Ads - two of the bolts - although totally unscrewed wont come out....tried gently then quite hard still cant prise it free. Cant believe Im going to have to take it to Audi just for s/wheel trim!!
Cheers Rick will give it another go.
Rick_RS4
Post by Rick_RS4 » Wed Aug 03, 2011 7:53 pm
the screws only screw in a couple of threads so if theyre loose it will come free, dont give up and let them do it for a stupid price, turn green and hulk it off
JZARS
Post by JZARS » Wed Aug 03, 2011 7:58 pm
Thanks Rick ...will use strength of the bear!! probably more like strength of the beer :)
wellzieRS4
Post by wellzieRS4 » Wed Aug 03, 2011 9:16 pm
i replaced mine not long back i just prised the front and back apart with a plasic spreader
JZARS
Post by JZARS » Thu Aug 04, 2011 7:32 pm
Pleased to report some level of success :beerchug:
Prised it apart, fitted new trim including shiny new rs4 badge :roll: . Now just need another pair of hands to squeeze it all together so I can screw it up, as I cant quite get each side close enough to bite at the back of s/wheel.
Thanks for the help!!!
ps I wasted £20 quid on a replacement badge via fleabay - badge on its own cant be replaced...doh.
Jonesy07
Post by Jonesy07 » Thu Aug 04, 2011 7:59 pm
See I thought it could ? Am I wrong ?
Current : S3 8p while on the RS3 hunt.
Previuos : B7 RS4 Avus Avant | RS4 Sal | R32 | Cayenne | Z4M | R32
wellzieRS4
Post by wellzieRS4 » Thu Aug 04, 2011 8:13 pm
thats just what i done its the wrong shape
adsgreen
Post by adsgreen » Thu Aug 04, 2011 9:30 pm
Sounds like you've got the older b5 rs4 logo that is a different shape
Rick_RS4
Post by Rick_RS4 » Thu Aug 04, 2011 10:46 pm
actually the badge can be replaced seperatly, as i recently did mine, cost just under £30
Jonesy07
Post by Jonesy07 » Thu Aug 04, 2011 10:54 pm
Rick_RS4 wrote:actually the badge can be replaced seperatly, as i recently did mine, cost just under £30
Did you get it direct from Audi ?
Rick_RS4
Post by Rick_RS4 » Thu Aug 04, 2011 11:02 pm
yeah, will post part number tomorrow for those interested
JohnnerLad
Post by JohnnerLad » Fri Aug 05, 2011 7:44 am
I got one freom fleabay and just use a knife to pop it out and super glued one back in looks great nothing wrong with it, but if you are just changing it out due to the missing black, i did fine out that you could just use a Black permanent marker and this again look great. I feel that i should have just used this in the first place! and saved myself £15
Mark
Users browsing this forum: Google [Bot] and 149 guests
