3k - 8k 3rd gear with VCDS, HOW TO?
Scatman
Post by Scatman » Tue Jun 07, 2011 9:01 pm
Hi,
Can anyone enlighten me on which option I click into in VCDS (rosstech) to time a 3000rpm-8000rpm run in 3rd gear?
Also, I tried the acceleration test, I hit start and set off but it doesn't register anything, is there something I might be doing wrong? The syste, says it's connected etc.
Help would be much appreciated!
:nogarors4:
rwilsonrs4
Re: 3k - 8k 3rd gear with VCDS, HOW TO?
Post by rwilsonrs4 » Wed Jun 08, 2011 4:27 pm
you dont need VCDS for this although i,m sure you could use it , use the lap timer in the dash that will give you a good enough idea
1/4 mile 12.01 secs 123.5mph
Macdaddy
Post by Macdaddy » Wed Jun 08, 2011 5:15 pm
No idea on your question but Dynolicious app on the iphones does all the timings...... If that helps :nodder:
B7 RS4 Cabriolet with custom Blueflame - Gone
Misano red RS3 running Stage 1 APR - Gone
Sepang B8 RS4 with buckets - Gone
Panther Black C7 RS6 - Current Daily
2manytoys
Post by 2manytoys » Thu Jun 09, 2011 9:42 am
Just log RPM and click the turbo button. Go about 2000 rpm and put your foot down until you hit the rev limit. Save the log and look at the time between 3000-8000.
The lap timer method is way to inaccurate let alone the validity of this test finding problems to start with.
If you've got Vagcom, log timing and correction, this will give you a better idea of potential problems.
Good luck.
Ice_Coffee
Post by Ice_Coffee » Thu Jun 09, 2011 6:20 pm
and post your results here, I wil do the same, for comparison !
Scatman
Post by Scatman » Thu Jun 09, 2011 8:08 pm
I'll do the logging at the weekend including timing and correction. Temps will be about 12c here at the weekend so nice and cool for accurate results
2manytoys
Post by 2manytoys » Fri Jun 10, 2011 10:26 am
If you log intake temp also that would be handy.
Here is mine (shortly after my new engine was run in, so this would be the closest representation of how the logs would have looked like from a brand new RS4)
Users browsing this forum: No registered users and 107 guests
