A2 bonnet vent dimensions?
Re: A2 bonnet vent dimensions?
If you're positioning it quite far back, perhaps you could fashion a drip tray and channel rain water into the (bizarrely named by audi) plenum chamber.
I'll be using similar drainage that Headshot used, so yes, the plenum chamber. The A2 vent is already built this way too, so bonus.
Interesting project bam, was thinking of adding vents but have been put off as wanted it to look oem as much as possible and struggling to find anything suitable. I;d be very interested to see how you get on - I suppose the only catch is if the curve of the a2 vent matches up with the curve of the rs bonnet line / base of the windscreen. Might look odd if it's too different?!..bam_bam wrote:I'll be using similar drainage that Headshot used, so yes, the plenum chamber. The A2 vent is already built this way too, so bonus.
RS6 C6 - Stock atm but will be getting an MRC Stage 2 shortly
RS6 C5 - H&R'd and MRC'd Happy Days!..
Yep, I've considered that but I won't really know until my bodyshop gets hold of all the pieces. They did say the vent could be slightly 'reshaped' with some heat and persuasion, maybe some harsh words and shouting but nothing more.vikingrs6 wrote:Interesting project bam, was thinking of adding vents but have been put off as wanted it to look oem as much as possible and struggling to find anything suitable. I;d be very interested to see how you get on - I suppose the only catch is if the curve of the a2 vent matches up with the curve of the rs bonnet line / base of the windscreen. Might look odd if it's too different?!..bam_bam wrote:I'll be using similar drainage that Headshot used, so yes, the plenum chamber. The A2 vent is already built this way too, so bonus.
Save your time and money mate, go to Halfrauds and buy some special chav bonnet lifting spacers
The Saxo boys would think it's well cool
Darth deserves the best
Edit scrap Halfrauds here's cheaper http://cgi.ebay.co.uk/Citroen-Saxo-Peug ... 3a5c0b624d
I'm just about to hit buy it now should i get a set for you too?
Only joking mate
Only joking mate
Lol whats the point in these bonnet lifters! Just makes it look like a bad fit to me!
A7 3.0T - Pretty Std at the moment... in warranty
VW Caddy 2k 1.9 TDI - Std
Has beens:
C5 RS6 Avant - Wagbo'd, PSS9, MiIltek Res, MRC Stage 2, ACE Torque Converter, 551ps 815nm | 00 B6 A4 2.5TDI | 01 Nissan R34 GTR V-Spec (UK) | 93 Toyota MR2 GT | 95 Mitsubishi FTO | BMW 318is | Vauxhall Corsa 1.4 16v SRI | Vauxhall Nova 1.3SR Chavtastic
Has beens:
Just when you thought chav couldn't get any chaver...
Makes it look like the car has been in an accident.
The Nissan GT-R has them as standard. All you have to do to activate them is to ram a pedestrian.
Good reading here: http://www.gtr.co.uk/forum/127250-accid ... i-did.htmlUnfortunately it also set off the Pedestrain Saftey system, where the bonnet pops up....
Which is a one use system....
You need to replace the bumper, rams, bonnet hinges....
and of course the ECU.
When the accident happened i called my dealer and asked them to collect the car and told them i would just pay for it without putting it through my insurance.
Then i found out the total cost of the repairs.
Eleven Thousand Pounds.
i like those breathers in the bonnet, that will look great in the RS6 bonnet...
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Yellow Koni's
The bonnet vent opening is 860 x 77mm the width is constant on the curve, I took the bonnet off but couldn't find a part No. as it's covered in plastic ducting below..
PS.. I now drive a 1.4 Tdi A2 instead of the S6
2000 Goodwood Green S6 4.2 V8 340bhp.
Hey bam bam lok what i found for you http://www.mtm-online.de/en/products/mt ... =m-rs6mhek
MTM bonnet gashes.
Thanks but no thanks Bilko. It looks like there was an underground sewer explosion, catapulting 3 storm water grates 100ft in the air and then they all landed on that RS6 bonnet. Fucken 'orrible IMHO.
I have no idea what MTM were thinking.
Cheers for the details Technics, very helpful.
That is very, very nasty.
Bam, did you do the sportec undertray mod? I saw RS6 Dave did...
My first thoughts on RS6.com was that the hole was begging for a stone to fly up between the timing belt and a roller and... well its obvious. I'd have to put some wire mesh there.
Where are the A2 vents going, and does this have anything to do with the undertray mod? Or just a separate heat vent?
SOLD - Avus RS6 Avant|KWV3|Hotchkis ARBs|RNSE|HighTech interior|Solar roof|Double glazed|Vreds|Non res Milltek|Phaeton brake ducts
VW T3|Avo 70mm drop|Subaru EJ25 motor|Audi 200 turbo trans|996 brakes|Peloquin LSD|RJES exhaust
Users browsing this forum: srichards and 118 guests
