Life? I dunno, would you reuse an alloy hat after the second or third set of discs.
I'm not trying to piss on your chips on purpose Mule, I'm just thinking out loud.
Brake Discs
Re: Brake Discs
Re: Brake Discs
Bam it's cool. I thought the same thing.
Begs the question: why are they designed to be two piece if not to swap over the hat on to a new set of rotors?
SOLD - Avus RS6 Avant|KWV3|Hotchkis ARBs|RNSE|HighTech interior|Solar roof|Double glazed|Vreds|Non res Milltek|Phaeton brake ducts
VW T3|Avo 70mm drop|Subaru EJ25 motor|Audi 200 turbo trans|996 brakes|Peloquin LSD|RJES exhaust
Re: Brake Discs
mrmule wrote:Bam it's cool. I thought the same thing.
Its to allow differing rates of expansion when heated. The main reason that solid cast discs warp is that they are clamped by the wheel hub and cannot evenly expand. A two piece construction allows the rotor section to expand evenly and avoid warping.
Re: Brake Discs
Are you done bam? We're all on a learning curve.bam_bam wrote:TOLD.
Thanks rs6brit. I can assume then that the bell doesn't have to bear the brunt of expansion and recoil so much, which supports the argument for reuse?
Re: Brake Discs
C'mon, that was a beautifully succinct answer from Brit.
The original design brief was for racing/sports use not re-purposing, but there's probably no reason why you can't reuse. Just inspect the <beep> out of those hats every time you change discs - maybe change the hardware/fixings at the same time, innit.
Users browsing this forum: philS2, Steve2003rs6 and 577 guests
