Brake Discs
mrmule
Re: Brake Discs
Post by mrmule » Sun May 08, 2011 7:05 pm
Is there evidence to say it would it be worse?
SOLD - Avus RS6 Avant|KWV3|Hotchkis ARBs|RNSE|HighTech interior|Solar roof|Double glazed|Vreds|Non res Milltek|Phaeton brake ducts
VW T3|Avo 70mm drop|Subaru EJ25 motor|Audi 200 turbo trans|996 brakes|Peloquin LSD|RJES exhaust
iR8V10
Re: Brake Discs
Post by iR8V10 » Sun May 08, 2011 7:06 pm
Sell a kidney. C6 set up FTW!
Re: Brake Discs
Post by Shoppinit » Sun May 08, 2011 8:19 pm
mrmule wrote:Is there evidence to say it would it be worse?
Not as far as I'm aware. Fair point. Go to it and let us know if it's better or worse :thumbs:
Re: Brake Discs
Post by Shoppinit » Sun May 08, 2011 8:20 pm
Anyone know how much the C6 set up costs approximately?
iR8V10
Re: Brake Discs
Post by iR8V10 » Sun May 08, 2011 8:23 pm
Shoppinit wrote:Anyone know how much the C6 set up costs approximately?
Grizz is the man....I was fortunate to get mine as part of a swap so not sure of costs.
stumpyrs4
Re: Brake Discs
Post by stumpyrs4 » Sun May 08, 2011 8:53 pm
bam_bam wrote:According to "StumpyRS4" the W12 Phaeton front discs are the same offset as C5 RS. Problem is, the bell might be slightly different, looks very similar to me, not that would mean anything. PM Stumpy, see what he says. Stumpy is an Audi Addict... if you know what I mean.
I am an Audi Addict !! :biggrin3:
Yes I've just PM'd Mr Mule...
They're a great alternative to OEM (Audi) discs, and at £300 a pair, great value too.
I've done 2x UK Track days (Brands Hatch and Snetterton) and 5x laps of the Ring with them, in the last 6 months and they worked fine, eh DK ?
The dia and thickness are the same, but the offset is different. But all you need do is swap over the hats between the new Phaeton discs and your old C5 discs when you're ready to change over, and hey presto...
:greyrs4:
B5 RS4 - now sold.
Re: Brake Discs
Post by bam_bam » Sun May 08, 2011 9:37 pm
The C5 RS doesn't have a removable hat. The OEM disc is held via pins. Stumps, I read it was a 6mm difference, which direction, in or out?
There are a couple of options for hats that do fit the C5. One guy on here had gone down the floating disc route... search is your friend.
stumpyrs4
Re: Brake Discs
Post by stumpyrs4 » Sun May 08, 2011 9:56 pm
Sorry, can't recall (vs B7 RS4) - no idea for C5 RS6.
Prolly best to have a chat with MRC/Unit 20/Bahnstorm etc
B5 RS4 - now sold.
Re: Brake Discs
Post by bam_bam » Sun May 08, 2011 10:02 pm
Quote from another forum:
"Phaeton 15.56mm offset
RS4 2.56mm offset
This is the offsets on the hats, so this disc will be ~13mm more inset on the phaeton.
IIRC the RS6 disc is only ~6mm more inset than RS4"
Mule, you'll need to get some replacement bells for these to fit the C5.
mrmule
Re: Brake Discs
Post by mrmule » Mon May 09, 2011 7:45 am
bam_bam wrote:There are a couple of options for hats that do fit the C5.
Which are these bam?
Re: Brake Discs
Post by Shoppinit » Mon May 09, 2011 7:48 am
It might be easier to modify the caliper rails to suit. Depending on the offset, you might just need some spacers.
mrmule
Re: Brake Discs
Post by mrmule » Mon May 09, 2011 7:51 am
Have I understood correctly Shop? So some 7mm spacers (based on quote from other forum comps of bam) between disc and hub and the phaeton disc will work?
Re: Brake Discs
Post by Shoppinit » Mon May 09, 2011 7:58 am
You have to get your height / girth / diameter / whatever you call to see how it would present. Maybe spacers would do it, or a simple adapter plate.
Anyway, isn't spacers what people use to get the rear phaeton disks on?
mrmule
Re: Brake Discs
Post by mrmule » Mon May 09, 2011 8:39 am
Yes about 3mm gets you in the centre of the caliper. But this spacer/washer steps the carrier of the caliper out (actually in to the car), not the disc itself.
You're proposing a similar approach? 7mm is a big spacer for the caliper. I think I'd prefer a solution for the disc itself.
Finding a replacement bell for the phaeton disc sounds like the better option... Bam? Only thing I dont get is that the Phaeton front discs I have seen do not have a bell which is bolted to the disc. So how does this get swapped over if it's one big unit?
Re: Brake Discs
Post by Shoppinit » Mon May 09, 2011 8:51 am
The hat itself doesn't look very complicated. Probably wouldn't cost much* to get one machine to the right dimensions;
(* everything is relative. Might cost more than you are willing to spend)
Users browsing this forum: Google Adsense [Bot] and 105 guests
