SD card operation
Re: SD card operation
Thanks for all the above I had got it right just needed to hit return.... Doh
Dave - what is latest ID3 tag version accepted?PetrolDave wrote: The RNS-E cannot accept files with later version of the ID3 tag.
The file breaking this rule AND ALL FILES AFTER will be ignored.
Also have you ever seen this phenomenon? Track plays fine but as a new track is played, the (previously fine) track name gets replaced with a symbol (sort of like IO ).
Normally I do not do
artist > album > track title
as I fear a long track title could screw things up, I use
artist > track title
as I rarely have more than 1 album by the same artist on the same card
It only happens on one Kings of Leon album which I accidentally added as a subset of another KOL album so my suspicion is the pathname was too long - so its:
kings of leon>come around sundown>track titles
but it plays fine, just messes up the track names
- PetrolDave
ID3.1 IIRCAdam wrote:Dave - what is latest ID3 tag version accepted?
Do you have a 2010+ RNS-E, or the older version (as fitted by Audi to the RS4).Adam wrote:Also have you ever seen this phenomenon? Track plays fine but as a new track is played, the (previously fine) track name gets replaced with a symbol (sort of like IO ).
That's been reported by several people on www.audiforum.us - but only on the 2010+ RNS-E and is fixed with the latest SW.
Totally bought the wrong card... Got a 16gig sd card.... Clearly doesnt work... Thanks for pointing this newbie in the right direction tho!
Mark
Mark
- Steve_C
- Top Gear
I presume you mean that you got a SDHC card? Max SD card capacity is 4gb and should work.MarkMRS4 wrote:Totally bought the wrong card... Got a 16gig sd card.... Clearly doesnt work... Thanks for pointing this newbie in the right direction tho!
Mark
Gone to the dark side
- PetrolDave
SD card <= 4GB ----> only this works in the pre-2010 RNS-E as fitted to the B7 RS4Steve_C wrote:I presume you mean that you got a SDHC card? Max SD card capacity is 4gb and should work.
SDHC card >= 4GB (max 32GB)
SDXC >= 64GB (max 2TB)
So 16GB is an SDHC card, even if the vendor incorrectly describes it as an SD card.
I have original RNS-E as fitted on my 2007 car, have never updated the SWPetrolDave wrote: Do you have a 2010+ RNS-E, or the older version (as fitted by Audi to the RS4).
That's been reported by several people on http://www.audiforum.us - but only on the 2010+ RNS-E and is fixed with the latest SW.
using 4gb SD cards
Luckily did a search before posting and this worked spot on for me too, gosh it wasn't intuative.BenWat wrote:Thanks for all the above I had got it right just needed to hit return.... Doh
Users browsing this forum: Bing [Bot] and 226 guests
