SD card operation
BenWat
Re: SD card operation
Post by BenWat » Sun May 01, 2011 10:22 pm
Thanks for all the above I had got it right just needed to hit return.... Doh
Adam
Post by Adam » Thu May 05, 2011 9:49 am
PetrolDave wrote: The RNS-E cannot accept files with later version of the ID3 tag.
The file breaking this rule AND ALL FILES AFTER will be ignored.
Dave - what is latest ID3 tag version accepted?
Also have you ever seen this phenomenon? Track plays fine but as a new track is played, the (previously fine) track name gets replaced with a symbol (sort of like IO ).
Normally I do not do
artist > album > track title
as I fear a long track title could screw things up, I use
artist > track title
as I rarely have more than 1 album by the same artist on the same card
It only happens on one Kings of Leon album which I accidentally added as a subset of another KOL album so my suspicion is the pathname was too long - so its:
kings of leon>come around sundown>track titles
but it plays fine, just messes up the track names :?
PetrolDave
Post by PetrolDave » Thu May 05, 2011 4:25 pm
Adam wrote:Dave - what is latest ID3 tag version accepted?
ID3.1 IIRC
Adam wrote:Also have you ever seen this phenomenon? Track plays fine but as a new track is played, the (previously fine) track name gets replaced with a symbol (sort of like IO ).
Do you have a 2010+ RNS-E, or the older version (as fitted by Audi to the RS4).
That's been reported by several people on www.audiforum.us - but only on the 2010+ RNS-E and is fixed with the latest SW.
MarkMRS4
Post by MarkMRS4 » Fri May 06, 2011 1:37 am
Totally bought the wrong card... Got a 16gig sd card.... Clearly doesnt work... Thanks for pointing this newbie in the right direction tho!
Mark
Steve_C
Post by Steve_C » Fri May 06, 2011 8:47 am
MarkMRS4 wrote:Totally bought the wrong card... Got a 16gig sd card.... Clearly doesnt work... Thanks for pointing this newbie in the right direction tho!
Mark
I presume you mean that you got a SDHC card? Max SD card capacity is 4gb and should work.
Gone to the dark side
PetrolDave
Post by PetrolDave » Fri May 06, 2011 3:55 pm
Steve_C wrote:I presume you mean that you got a SDHC card? Max SD card capacity is 4gb and should work.
SD card <= 4GB ----> only this works in the pre-2010 RNS-E as fitted to the B7 RS4
SDHC card >= 4GB (max 32GB)
SDXC >= 64GB (max 2TB)
So 16GB is an SDHC card, even if the vendor incorrectly describes it as an SD card.
Adam
Post by Adam » Tue May 10, 2011 10:29 am
PetrolDave wrote: Do you have a 2010+ RNS-E, or the older version (as fitted by Audi to the RS4).
That's been reported by several people on http://www.audiforum.us - but only on the 2010+ RNS-E and is fixed with the latest SW.
I have original RNS-E as fitted on my 2007 car, have never updated the SW
using 4gb SD cards
SRB
Post by SRB » Mon Jun 06, 2011 8:15 pm
BenWat wrote:Thanks for all the above I had got it right just needed to hit return.... Doh
Luckily did a search before posting and this worked spot on for me too, gosh it wasn't intuative.
Users browsing this forum: No registered users and 218 guests
