Rear brake discs and pads, fitting?
- seanypeeps
Hi guys done lots of searches but not really getting why I want on this. Has anyone ever done a rear disc and pad fitting guide as mine need doing and I'm not paying a garage/stealer to do it if it's pretty straight forward. I've done other cars before now but would just like a little guide if possible and is there any special tools or fitting kits needed? If you know of a link that would be great help! Cheers Sean.
Re: Rear brake discs and pads, fitting?
You need an VAG tool to wind the pistons back into the calipers I understand.
Mart.
Mart.
C6 RS6 Plus with a few sensible mods...
Halfords do a LASER brand caliper rewind tool, that is all you need by way of specialist tools. It's quite straightforward.
Don't press the brake when the rear caliper is removed.
Draper do one too.
SOLD - Avus RS6 Avant|KWV3|Hotchkis ARBs|RNSE|HighTech interior|Solar roof|Double glazed|Vreds|Non res Milltek|Phaeton brake ducts
VW T3|Avo 70mm drop|Subaru EJ25 motor|Audi 200 turbo trans|996 brakes|Peloquin LSD|RJES exhaust
http://shop.ebay.co.uk/?_from=R40&_trks ... Categories
Not sure if the RS6 has left and right handed pistons so you might get away with a cheap one.
I did mine about three weeks ago and yes it is very much straight forward.
But I do have a toolset like in Bilko1's link. Make sure you check your brake fluid level before you start pushing back the piston.
My fluid was filled up while the pads were half worn, so I spilled some unfortunately.
STOLEN : Das phantom: Ebony Black, RS6+ optic package in- and outside, some sort of ECU remap, sportec exhaust, 275/30 19 with RS6+ rims. --> "GTA is da new name of da game. "
- rutland-boy
http://www.yellowdogracing.com/Audibrakes.htm might be some help.......use at your own risk (!!), I havent tried it, but looks pretty straightforward as long as you have the 'special' tool, others above have said where you can get this - draper etc.seanypeeps wrote:Hi guys done lots of searches but not really getting why I want on this. Has anyone ever done a rear disc and pad fitting guide as mine need doing and I'm not paying a garage/stealer to do it if it's pretty straight forward. I've done other cars before now but would just like a little guide if possible and is there any special tools or fitting kits needed? If you know of a link that would be great help! Cheers Sean.
RS6 - Mugello Blue - 2003
Upgraded RNS-E
Upgraded RNS-E
I bought one from halfrauds. Easiest job in the world.Ceveman73 wrote:You need an VAG tool to wind the pistons back into the calipers I understand.
Mart.
