Rear brake discs and pads, fitting?
seanypeeps
Post by seanypeeps » Tue Mar 22, 2011 11:53 am
Hi guys done lots of searches but not really getting why I want on this. Has anyone ever done a rear disc and pad fitting guide as mine need doing and I'm not paying a garage/stealer to do it if it's pretty straight forward. I've done other cars before now but would just like a little guide if possible and is there any special tools or fitting kits needed? If you know of a link that would be great help! Cheers Sean.
Ceveman73
Re: Rear brake discs and pads, fitting?
Post by Ceveman73 » Tue Mar 22, 2011 12:31 pm
You need an VAG tool to wind the pistons back into the calipers I understand.
Mart.
C6 RS6 Plus with a few sensible mods...
Rupert
Post by Rupert » Tue Mar 22, 2011 1:04 pm
Halfords do a LASER brand caliper rewind tool, that is all you need by way of specialist tools. It's quite straightforward.
Don't press the brake when the rear caliper is removed.
mrmule
Post by mrmule » Wed Mar 23, 2011 7:44 pm
Draper do one too.
SOLD - Avus RS6 Avant|KWV3|Hotchkis ARBs|RNSE|HighTech interior|Solar roof|Double glazed|Vreds|Non res Milltek|Phaeton brake ducts
VW T3|Avo 70mm drop|Subaru EJ25 motor|Audi 200 turbo trans|996 brakes|Peloquin LSD|RJES exhaust
bilko1
Post by bilko1 » Wed Mar 23, 2011 10:22 pm
http://shop.ebay.co.uk/?_from=R40&_trks ... Categories
Not sure if the RS6 has left and right handed pistons so you might get away with a cheap one.
micdee
Post by micdee » Sat Mar 26, 2011 9:27 am
I did mine about three weeks ago and yes it is very much straight forward.
But I do have a toolset like in Bilko1's link. Make sure you check your brake fluid level before you start pushing back the piston.
My fluid was filled up while the pads were half worn, so I spilled some unfortunately.
STOLEN : Das phantom: Ebony Black, RS6+ optic package in- and outside, some sort of ECU remap, sportec exhaust, 275/30 19 with RS6+ rims. --> "GTA is da new name of da game. "
rutland-boy
Post by rutland-boy » Sat Apr 09, 2011 10:44 pm
seanypeeps wrote:Hi guys done lots of searches but not really getting why I want on this. Has anyone ever done a rear disc and pad fitting guide as mine need doing and I'm not paying a garage/stealer to do it if it's pretty straight forward. I've done other cars before now but would just like a little guide if possible and is there any special tools or fitting kits needed? If you know of a link that would be great help! Cheers Sean.
http://www.yellowdogracing.com/Audibrakes.htm might be some help.......use at your own risk (!!), I havent tried it, but looks pretty straightforward as long as you have the 'special' tool, others above have said where you can get this - draper etc.
RS6 - Mugello Blue - 2003
Upgraded RNS-E
Post by Shoppinit » Sun Apr 10, 2011 7:11 pm
Ceveman73 wrote:You need an VAG tool to wind the pistons back into the calipers I understand.
Mart.
I bought one from halfrauds. Easiest job in the world.
