Guys...
got 2 error codes can you help?
19497
17983
error codes
- Gravitypilot
error codes
03 Mugello Pearl Avant 32K
MTM Tuned, Vreds, Miltek 520+
Need any parts? just give me a shout on PM
Re: error codes
19479: Powertrain Databus, Implausible Engine Temperature Message from Inst.Panel
17983: Right Engine Mount Solenoid Valve, Short to B+
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Yellow Koni's
Re: error codes
The 1st one sounds like water infiltration into the can bus module under the passenger side carpet. Check for blocked drains and wet carpet. I can't see it being anything else.
The 2nd one could be related to the first, or might indicate a dead engine mount. Can be changed relatively easily or left alone. I remember seeing a connector you could buy to fool the ECU into thinking it was still working.
Personally I'd replace it. If they bothered to go to the trouble of putting active engine mounts in, then I'd make sure it works
Re: error codes
They did put a few things into the RS6 that are questionable at best thoughShoppinit wrote: Personally I'd replace it. If they bothered to go to the trouble of putting active engine mounts in, then I'd make sure it works
B7 RS4 saloon Misano red, comfy seats, JHM tune & JHM full exhaust with cats and resonators - gone.
C5 RS6 Avant Daytona/Cognac - gone.
981 Cayman GTS Gray/Orange.
My youtube
My youtube
Re: error codes
Jamiroquai for one...JCviggen wrote: They did put a few things into the RS6 that are questionable at best though
Users browsing this forum: Google [Bot] and 233 guests
