error codes
Gravitypilot
error codes
Post by Gravitypilot » Mon Apr 04, 2011 9:22 am
Guys...
got 2 error codes can you help?
19497
17983
03 Mugello Pearl Avant 32K
MTM Tuned, Vreds, Miltek 520+ :-)
Need any parts? just give me a shout on PM
mavada
Re: error codes
Post by mavada » Mon Apr 04, 2011 9:26 am
19479: Powertrain Databus, Implausible Engine Temperature Message from Inst.Panel
17983: Right Engine Mount Solenoid Valve, Short to B+
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Re: error codes
Post by Shoppinit » Mon Apr 04, 2011 11:59 am
The 1st one sounds like water infiltration into the can bus module under the passenger side carpet. Check for blocked drains and wet carpet. I can't see it being anything else.
The 2nd one could be related to the first, or might indicate a dead engine mount. Can be changed relatively easily or left alone. I remember seeing a connector you could buy to fool the ECU into thinking it was still working.
Personally I'd replace it. If they bothered to go to the trouble of putting active engine mounts in, then I'd make sure it works :thumbs:
JCviggen
Re: error codes
Post by JCviggen » Mon Apr 04, 2011 1:04 pm
Shoppinit wrote: Personally I'd replace it. If they bothered to go to the trouble of putting active engine mounts in, then I'd make sure it works :thumbs:
They did put a few things into the RS6 that are questionable at best though :audibash:
B7 RS4 saloon Misano red, comfy seats, JHM tune & JHM full exhaust with cats and resonators - gone.
C5 RS6 Avant Daytona/Cognac - gone.
981 Cayman GTS Gray/Orange.
My youtube
Re: error codes
Post by Shoppinit » Mon Apr 04, 2011 1:21 pm
JCviggen wrote: They did put a few things into the RS6 that are questionable at best though :audibash:
Jamiroquai for one...
Users browsing this forum: Majestic-12 [Bot] and 155 guests
