ABS light on
ABS light on
Hi chaps, Got a RS6 avant on a 04 plate ABS light keeps coming on intermittently, had a mate put his code reader on it and found trouble code c00287 rear right wheel speed sensor open circuit or short to ground, ive changed the sensor and still no joy ive had the wiring checked all ok, what i want to ask has anyone had problems with the control unit.
Re: ABS light on
I had the control unit replaced on mine after it was showing the same symptoms as you and was verified as a faulty unit by Audi.It was replaced under warranty for £1300 or thereabouts.It might just be the brake switch which also causes the abs light to come on and that is significantly cheaper
2003 RS6 Avant (NOW SOLD)
Re: ABS light on
Try cleaning the connector at the ECU, and checking the continuity of the loom for that side using the diagrams on ELSA. I still think it would be a wiring issue if it is only coming up for one sensor.
Re: ABS light on
Check the wiring out before you do anything! Like golf says may just be a lose connection.
Steve
RS6 gone, R32 gone, M3 gone, Porsche Cayenne Turbo gone, Boring A6 saloon gone, Boring A6 Avant going in 5 weeks
. Maybe RS5 or S5 Hatchback to come...
Re: ABS light on
just had new abs module , fitted under warranty , all warning lights on , Audi diagnosis , Warranty Direct payout , eventually
Now : XFR Jag 5.0 Supercharged
Used to have : C5 Daytona Avant , silver leather , carbon inserts ; RNSE, TV in motion, Bluetooth , well filled SD card slots ; PSS9's ; Hotchkiss ARB's ; Miltek cat back res ; Wagner intercoolers ; Phaeton brake ducts ; forge DV's ;
Re: ABS light on
Hi guys thanks for the reply, i took on the job of testing the wires my self yesterday and all reading good, road tested with a diagnostic tester to carry out a data list of the sensors all working ok, so im thinking its possibly the ecu, any thoughts before i get it replaced.
Re: ABS light on
When my abs light was coming on,turned out to be brake pedal switch,as also sends feed to abs system so i was told,20 pound fix,been fine for 6 months,touch wood...WAFFY...
RS 6 Avant,
Ebony black mettallic,03 plate,
H&R coilovers,
miltek back boxes,
pirelli p zero's,
H&R coilovers,
miltek back boxes,
pirelli p zero's,
Re: ABS light on
Did you sort this?
Re: ABS light on
No not yet, trying to get time but juggling a misses and three kids is exhausting, but i will defo crack on with it soon.
Users browsing this forum: Bing [Bot], Google Adsense [Bot] and 197 guests
