About Ceramic Brakes
Revo
Post by Revo » Mon Jan 10, 2011 11:50 pm
Hi to all,
i have some concerns about ceramic brake swap.
I bought my b7 rs4 with 8 pot regular rs4 brake system. And then changed it to 380mm Ceramic brake system.
We just changed ; brake calipers, brake pads and brake discs.
Do i need to change anything else for this swap ?
I will change brake fluids and will add SS lines in near future.
My brake pedal is much softer, is that ok ?
Do i need to change the disc dust shield for 380mm rotor ?
RS6chris!
RE: About Ceramic Brakes
Post by RS6chris! » Mon Jan 10, 2011 11:56 pm
I think you also have to tell the cars ECU also...something to do with the ABS???
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
Post by HYFR » Mon Jan 10, 2011 11:56 pm
did you reprogramme via VDCS ?
I may be wrong, but im pretty sure the pads slightly wipe against the discs when your wipers go for rain, as ceramics are about as good as an elephant on ice skates when wet
Revo
Post by Revo » Tue Jan 11, 2011 12:00 am
Yes we did the programming.
Changed the ESP and brakes in airbag adaptation.
PetrolDave
Re: RE: About Ceramic Brakes
Post by PetrolDave » Tue Jan 11, 2011 10:31 am
Revo wrote:Changed the ESP and brakes in airbag adaptation.
The airbag controller is completely separate to the ABS controller?
Doug_S2
Trader (Expired)
RE: Re: RE: About Ceramic Brakes
Post by Doug_S2 » Tue Jan 11, 2011 11:21 am
Pedal should feel as firm as steel brakes
http://www.MRCtuning.com
Revo
Post by Revo » Tue Jan 11, 2011 4:07 pm
This write is from another audi forum and about ceramic brake VAG-COM adaptation.
"Here are the coding instructions from the CD-ROM:
Coding
Possible ESP versions:
Steel Brakes
Brakes in airbag adaptation channel 51: 22
ESP version: 4533
Ceramic Brakes
Brakes in airbag adaptation channel 51: 20
ESP version: 4534"
Revo
Re: RE: Re: RE: About Ceramic Brakes
Post by Revo » Tue Jan 11, 2011 4:10 pm
Doug_S2 wrote:Pedal should feel as firm as steel brakes
This is not good. My brake feel is much more different then before.
Any idea about the issue ?
At first i thought that it can be because of the different calipers. 8pot vs 6 pot
Doug_S2
Trader (Expired)
RE: Re: RE: Re: RE: About Ceramic Brakes
Post by Doug_S2 » Wed Jan 12, 2011 9:38 am
I would bleed all 4 brakes a couple of times then go and bed your brakes in - i fitted used ceramics to mine so where already bedded in - i am not sure what pads are like on ceramics that are not bedded in.
Revo
Post by Revo » Wed Jan 12, 2011 4:55 pm
I am waiting for the front and rear SS lines, after they arrive i will bleed all 4 brakes, thanks.
Rick_RS4
Post by Rick_RS4 » Wed Jan 12, 2011 5:17 pm
i see the big dick points in ceramics but are they really worth the money? i moved from 4 pots to now 8 post and they are very good still bedding the new disks and pads at the moment tho.
Revo
Post by Revo » Wed Jan 12, 2011 10:45 pm
After the 8pot, this ceramics are different world imo.
We dont have much speed controls on the autobahns so we can reach high speeds most of the time.
After some hard pushes (especially from 200+km/h) it still holds great.
Doug_S2
Trader (Expired)
Post by Doug_S2 » Wed Jan 12, 2011 10:59 pm
If you track your car or drive it hard - the consistancy is worth it
S4Player
Post by S4Player » Thu Jan 13, 2011 12:59 am
Just about to go ahead with movit ceramics should be here in 4-6 weeks
Revo
Post by Revo » Thu Jan 13, 2011 9:35 pm
Can you share the price ?
ps : i cant catch :(
Users browsing this forum: No registered users and 1563 guests
