About Ceramic Brakes
Hi to all,
i have some concerns about ceramic brake swap.
I bought my b7 rs4 with 8 pot regular rs4 brake system. And then changed it to 380mm Ceramic brake system.
We just changed ; brake calipers, brake pads and brake discs.
Do i need to change anything else for this swap ?
I will change brake fluids and will add SS lines in near future.
My brake pedal is much softer, is that ok ?
Do i need to change the disc dust shield for 380mm rotor ?
RE: About Ceramic Brakes
I think you also have to tell the cars ECU also...something to do with the ABS???
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
did you reprogramme via VDCS ?
I may be wrong, but im pretty sure the pads slightly wipe against the discs when your wipers go for rain, as ceramics are about as good as an elephant on ice skates when wet
Yes we did the programming.
Changed the ESP and brakes in airbag adaptation.
- PetrolDave
Re: RE: About Ceramic Brakes
The airbag controller is completely separate to the ABS controller?Revo wrote:Changed the ESP and brakes in airbag adaptation.
RE: Re: RE: About Ceramic Brakes
Pedal should feel as firm as steel brakes
http://www.MRCtuning.com
This write is from another audi forum and about ceramic brake VAG-COM adaptation.PetrolDave wrote:The airbag controller is completely separate to the ABS controller?Revo wrote:Changed the ESP and brakes in airbag adaptation.
"Here are the coding instructions from the CD-ROM:
Coding
Possible ESP versions:
Steel Brakes
Brakes in airbag adaptation channel 51: 22
ESP version: 4533
Ceramic Brakes
Brakes in airbag adaptation channel 51: 20
ESP version: 4534"
Re: RE: Re: RE: About Ceramic Brakes
This is not good. My brake feel is much more different then before.Doug_S2 wrote:Pedal should feel as firm as steel brakes
Any idea about the issue ?
At first i thought that it can be because of the different calipers. 8pot vs 6 pot
RE: Re: RE: Re: RE: About Ceramic Brakes
I would bleed all 4 brakes a couple of times then go and bed your brakes in - i fitted used ceramics to mine so where already bedded in - i am not sure what pads are like on ceramics that are not bedded in.
I am waiting for the front and rear SS lines, after they arrive i will bleed all 4 brakes, thanks.
i see the big dick points in ceramics but are they really worth the money? i moved from 4 pots to now 8 post and they are very good still bedding the new disks and pads at the moment tho.
After the 8pot, this ceramics are different world imo.
We dont have much speed controls on the autobahns so we can reach high speeds most of the time.
After some hard pushes (especially from 200+km/h) it still holds great.
If you track your car or drive it hard - the consistancy is worth it
Just about to go ahead with movit ceramics should be here in 4-6 weeks
Can you share the price ?
ps : i cant catch
ps : i cant catch
Users browsing this forum: Google Adsense [Bot] and 835 guests
