Few issues?
EuroSag
Few issues?
Post by EuroSag » Mon Dec 06, 2010 9:59 pm
So, the RS4 Avant is starting to get old.....
1. Steering makes like a squeeling noise every now and then.
2. Brakes judder under hard(ish) braking. Discs are ok.
3. Rear end seems to be sitting really low even with empty boot.
Do you think 2 and 3 relate to DRC?
Anyone got any idea's about 1?
Cheers,
Porsche 997 GT3 - 2010/60
Porsche 997 GT2FS - 2008/58
Peugeot 205 1.9 GTI-S - 1991/J
Audi B7 RS4 Saloon - 2007/07
Audi Q7 3.0TDI - 2011/11
Alfa 147 GTA - 2003/53
Ford F150 Raptor - 2012/62
ShaneyB
RE: Few issues?
Post by ShaneyB » Mon Dec 06, 2010 10:08 pm
Is the squeeling on full lock in reverse?
Warped discs?
Got any pics?
Shane
Current
2017 C7 Nardo RS6 Performance
Gone:
C43 AMG Coupe
Black E92 M3
Daytona B7 RS4 Saloon
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Cavalier 1.8 lsi
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Phil3103
RE: Few issues?
Post by Phil3103 » Mon Dec 06, 2010 10:26 pm
1. Does the power steering work using a belt. Could it just be damp? Possible leak on to it from somewhere?
2. Have a look on here somewhere about doing a 'clean' of the brakes. A hard run followed by hard braking, then let them cool and repeat a few times. Something like that. Failing that, it's probably warped discs. Many on here have had the same issues even on relatively new discs.
3. If you've got SS+ it sits lower at the back anyway (or is this just the saloon - I forget). Any sort of suspension issue points to the DRC unfortunately. But just remember the 5y guarantee from Audi UK. If you struggle again there's a copy of letters from Jeremy Hicks knocking around on here that you could show to the dealer.
Hope that helps. Stick with it.
EuroSag
Re: RE: Few issues?
Post by EuroSag » Mon Dec 06, 2010 11:44 pm
Shagga wrote:Is the squeeling on full lock in reverse?
Sometimes, but also when moving forwards on full lock. More noticeable when manouvering at low speeds like parking in a tight spot etc...
P_G
Post by P_G » Mon Dec 06, 2010 11:45 pm
Stick with it.
I had occasional judder but with usage it is fading out, worst case get them skimmed but you just need to work it if it is the fronts or rears. My Avant also sits low at rear compared to front but DRC pressure is just fine, just seems to be a trait with Avants. Not sure about your squeel, check hydraulic fluid level especially if you notice it in the cold.
NOMISEGDELP
Post by NOMISEGDELP » Tue Dec 07, 2010 12:13 am
My judder at 46k was a worn track rod end. It gradually got worse over 500miles - meanwhile I'd tried all the disc bedding stuff.
Terry1948
Post by Terry1948 » Tue Dec 07, 2010 5:18 pm
Just a thought have you checked your fluid level on the power steering. It might just be that it is going into bypass on full lock.
approved
Post by approved » Tue Dec 07, 2010 5:39 pm
mine squeels slightly on full locks...a few cars i've had have done it.
given its only on full lock about twice a week, for about 5 seconds, i've not looked into it...
dont they all do it?
adsgreen
Post by adsgreen » Tue Dec 07, 2010 6:53 pm
Simple solution - don't keep on full lock ;-) seriously though can damage the pump and says to avoid it in the manual.
However, yes mine does it too. However need to try it since having the steering rack reattached (!)
Users browsing this forum: No registered users and 220 guests
