Few issues?
Few issues?
So, the RS4 Avant is starting to get old.....
1. Steering makes like a squeeling noise every now and then.
2. Brakes judder under hard(ish) braking. Discs are ok.
3. Rear end seems to be sitting really low even with empty boot.
Do you think 2 and 3 relate to DRC?
Anyone got any idea's about 1?
Cheers,
Cheers,
Porsche 997 GT3 - 2010/60
Porsche 997 GT2FS - 2008/58
Peugeot 205 1.9 GTI-S - 1991/J
Audi B7 RS4 Saloon - 2007/07
Audi Q7 3.0TDI - 2011/11
Alfa 147 GTA - 2003/53
Ford F150 Raptor - 2012/62
RE: Few issues?
Is the squeeling on full lock in reverse?
Warped discs?
Got any pics?
Warped discs?
Got any pics?
Shane
Current
2017 C7 Nardo RS6 Performance
Gone:
C43 AMG Coupe
Black E92 M3
Daytona B7 RS4 Saloon
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Cavalier 1.8 lsi
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
RE: Few issues?
1. Does the power steering work using a belt. Could it just be damp? Possible leak on to it from somewhere?
2. Have a look on here somewhere about doing a 'clean' of the brakes. A hard run followed by hard braking, then let them cool and repeat a few times. Something like that. Failing that, it's probably warped discs. Many on here have had the same issues even on relatively new discs.
3. If you've got SS+ it sits lower at the back anyway (or is this just the saloon - I forget). Any sort of suspension issue points to the DRC unfortunately. But just remember the 5y guarantee from Audi UK. If you struggle again there's a copy of letters from Jeremy Hicks knocking around on here that you could show to the dealer.
Hope that helps. Stick with it.
Re: RE: Few issues?
Sometimes, but also when moving forwards on full lock. More noticeable when manouvering at low speeds like parking in a tight spot etc...Shagga wrote:Is the squeeling on full lock in reverse?
Stick with it.
I had occasional judder but with usage it is fading out, worst case get them skimmed but you just need to work it if it is the fronts or rears. My Avant also sits low at rear compared to front but DRC pressure is just fine, just seems to be a trait with Avants. Not sure about your squeel, check hydraulic fluid level especially if you notice it in the cold.
- NOMISEGDELP
- 1st Gear
Users browsing this forum: Squadr0n_ and 303 guests
