Suggestions for keeping your RS4 in tip-top form
wolfgang
Post by wolfgang » Thu Dec 02, 2010 10:49 am
I'm just trying to build a list of tips on keeping your RS4 in tip-top condition. Having spent many hours on the forum, i've got the following so far:
1. Use decent fuel (like Shell V-Power)
2. Get the wheels aligned
3. Switch to fixed service intervals
4. Get the latest software update (SW0090)
5. Use decent tyres (eg. Goodyear F1 Eagle Asymmetrics)
Any others?
2007 RS4 Avant in Mugello Blue + Milltek non-res valved, MRC air filter, MRC remap with silent-mode startup
ShaneyB
RE: Suggestions for keeping your RS4 in tip-top form
Post by ShaneyB » Thu Dec 02, 2010 11:19 am
Rubber mats in the winter.
Shane
Current
2017 C7 Nardo RS6 Performance
Gone:
C43 AMG Coupe
Black E92 M3
Daytona B7 RS4 Saloon
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Cavalier 1.8 lsi
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
P_G
Post by P_G » Thu Dec 02, 2010 11:24 am
Drive it as an every day car. Let it warm up gently to full engine temperature and then take it for long runs using the full rev range including some motorway driving. And don't be afraid to give the brakes some punishment either every now and again.
approved
Post by approved » Thu Dec 02, 2010 11:29 am
get it up to temp.
and abuse it, regularly
rs4nick
Post by rs4nick » Thu Dec 02, 2010 12:24 pm
Are supermarket super plus fuels (e.g. Tesco Momentum 99 & Sainsburys Super Plus) considered decent fuel? Any views as currently tends to be supermarket fuel that I use but always super plus and not std unleaded. Or should I steer clear?
andre3k
Post by andre3k » Thu Dec 02, 2010 12:41 pm
I read an article some time ago and the consensus was Tesco 99 (Momentum) was superior to the Shell equivalent. Can't remember what the exact criteria was for measurement (increase in hp, fuel efficiency, or something else)
wolfgang
Post by wolfgang » Thu Dec 02, 2010 1:11 pm
Doesn't Tesco 99 have a (relatively) high ethanol content to get it to 99-RON classification?
Post by HYFR » Thu Dec 02, 2010 1:15 pm
I used Tesco 99 for 10k in my B7 ... Brilliant
The B7 LOVES to rev, so ring its neck out when warm
Wash and wax regularly, espcially in salty weather
Keep an eye on oil as some love to drink it
Change oil every 5k if possible ... Should only cost £150
wolfgang
Post by wolfgang » Thu Dec 02, 2010 1:17 pm
Check and set the correct tyre pressures regularly.
neckarsulm
Post by neckarsulm » Thu Dec 02, 2010 4:11 pm
Halve the service intervals for oil, plugs and air filter
Clay bar the paint each summer
Lubricate exhaust flap linkages
If you have buckets, chose carefully how you get in and out of the car :)
wellzieRS4
Post by wellzieRS4 » Thu Dec 02, 2010 4:25 pm
I would use shell remember when dirty supermarket fuels fucked loads of cars up couple of years ago
PetrolDave
Post by PetrolDave » Thu Dec 02, 2010 4:36 pm
Regularly take the "scenic route" home and drive it hard when you do.
P_G
Post by P_G » Thu Dec 02, 2010 5:30 pm
I used to use Momentum 99 all the time and it may be that just a change of fuel has perked the car up, however at present my RS prefers V-Power. Just feels throttle sharper and still returns similar mpg.
RS6chris!
Post by RS6chris! » Thu Dec 02, 2010 6:16 pm
P_G wrote:I used to use Momentum 99 all the time and it may be that just a change of fuel has perked the car up, however at present my RS prefers V-Power. Just feels throttle sharper and still returns similar mpg.
Could be the cold weather P-G?? Mine goes like stink when the air temp is freezing!!
shej
Post by shej » Thu Dec 02, 2010 7:04 pm
wolfgang wrote:Check and set the correct tyre pressures regularly.
What are the correct pressures on standard rims?
Users browsing this forum: lugars4, Quinten and 121 guests
