Front fogs removal?...
xyber
Post by xyber » Thu Sep 30, 2010 7:59 pm
My bad temper has beaten me, probably shouldn't have attempted it in the dark haha
Do you remove the plastic trim (I got the screw out but couldn't remove it?!)
Undo 2 screws on the outside edge of the lamp
Done
xyber
RE: Front fogs removal?...
Post by xyber » Sun Oct 03, 2010 2:29 pm
Turn flat head screw 90 degrees
Slide grill towards the centre of the bumper and then push inwards slightly to release clip
Remove 2 torx screws
Pull out lamp
And after all that the bulbs caused bulb errors so now I'll have to modify the bulbs because there's no way I'm going to cut into the main cable. So 100w 3.6 ohm resistors with heat sinks have been ordered
aligod78
Post by aligod78 » Mon Oct 04, 2010 12:29 pm
Is that something that can be modified in the cars software perhaps instead? VagCom'd?
xyber
Post by xyber » Mon Oct 04, 2010 12:51 pm
I don't think it is, but even if it was I wouldn't delete it because it's quite useful, but it's an easy fix, you just wire in a resistor to simulate the power usage of a bulb element.
aligod78
Post by aligod78 » Mon Oct 04, 2010 1:00 pm
Ok, ta. Was thinking of 'stealthing' mine at some point :)
Users browsing this forum: No registered users and 269 guests
