Question about Auto-boot function
sonny
Post by sonny » Fri Sep 17, 2010 12:45 pm
When one operates the boot button from the fob, does the boot open up fully under its own control, or do you have to assist at some point for the boot to open, i.e. it opens only a couple of inches, and then you have to open the boot before the struts operate?
Thanks :wink:
scottie1979
RE: Question about Auto-boot function
Post by scottie1979 » Fri Sep 17, 2010 12:55 pm
Mine opens all the way
sonny
Post by sonny » Fri Sep 17, 2010 1:05 pm
OK Thank you. does your boot lid have sprung loaded rubber bung (helper) at the edge of the boot lid?
^Qwerty^
Post by ^Qwerty^ » Fri Sep 17, 2010 1:49 pm
Mine opens all the way too
DuncS3
Post by DuncS3 » Fri Sep 17, 2010 2:29 pm
mine does if it feels like it - depends whether the car has a strop on - but yes it is meant to
pad125
Post by pad125 » Fri Sep 17, 2010 2:39 pm
Did I see somewhere that the 'fully opening' boot lid was an option, something about the gas struts being a differant type IIRC
Pie
Post by Pie » Fri Sep 17, 2010 2:45 pm
Supposed to open all the way although a few weeks ago I seen a Merc which had auto boot closure too.
<3 Gadgets!
3.141
_________________________________
'14 C63 AMG Edition 507
'07 B7 RS4 +Milltek Non-Res, Non-Valved (Sold)
'10 YZF R1 + Akrapovics
pippyrips
Re: RE: Question about Auto-boot function
Post by pippyrips » Fri Sep 17, 2010 2:47 pm
pad125 wrote:Did I see somewhere that the 'fully opening' boot lid was an option, something about the gas struts being a differant type IIRC
Correct, not a simple swap either as brackets etc also need to be changed.
sonny
RE: Re: RE: Question about Auto-boot function
Post by sonny » Fri Sep 17, 2010 3:20 pm
It was a £30 option.
You can have it fitted after market, all you need is the uprated piston, bracket and spring for each side, works out around £60 quid. Im having it fitted at the moment. just it a slight snag, where it wont open fully. so we are not sure if it needs a spring loaded grommet (like what is shown in the other thread about the rubber strip on boot). As these might have been added at a later date to stop the boot rubbing on the bumper...watch this space.
Can any of you guys confirm that you have the spring loaded grommet on the tail gate. thanks
PetrolDave
Re: RE: Re: RE: Question about Auto-boot function
Post by PetrolDave » Fri Sep 17, 2010 3:26 pm
sonny wrote:It was a £30 option.
IIRC only on the saloon, not on the cab or Avant.
sonny
RE: Re: RE: Re: RE: Question about Auto-boot function
Post by sonny » Fri Sep 17, 2010 3:30 pm
Yep thats right Dave. But how "cool" would a avant auto boot be (even though it would have to be one strong strut).
PetrolDave
Re: RE: Re: RE: Re: RE: Question about Auto-boot function
Post by PetrolDave » Fri Sep 17, 2010 4:22 pm
sonny wrote:But how "cool" would a avant auto boot be (even though it would have to be one strong strut).
I'd retrofit it if it were possible 8)
gdavison
Post by gdavison » Fri Sep 17, 2010 5:57 pm
Pie wrote:Supposed to open all the way although a few weeks ago I seen a Merc which had auto boot closure too.
<3 Gadgets!
FWFW - RS6 C6 Avants have power boot close .. maybes look to see if anything retrofits to the RS4 Avant ?
ArthurPE
Post by ArthurPE » Fri Sep 17, 2010 8:28 pm
mine only pops open a few inches, just unlatches
pretty sure all cars in the States are the same
no full opening option
karl
Post by karl » Fri Sep 17, 2010 11:14 pm
I understood from my local dealer that new boot hinges are required as they're a different design. I've got all the part no's listed if anyone wants them.
Users browsing this forum: No registered users and 170 guests
