1.8t tubular exhaust manifold DIY kit
jc..
Post by jc.. » Thu Sep 02, 2010 1:58 pm
jc..
RE: 1.8t tubular exhaust manifold DIY kit
Post by jc.. » Thu Sep 02, 2010 2:38 pm
Full set of parts required to build a custom tubular manifold for a VAG 1.8t head.
Bought for a project but neither my welder or my welding skills are up to the job.
Pipe is Sch10 1.5" 316 Stainless
12 x 90deg bends
4x 45 deg bend
6 x straight cut spacers
Head flange is 10mm 316 stainless laser cut with inter port notches for equal heat expansion.
Enough pipe and fitting to create a full rams horn equal length manifold such as a Fullrace style tubular mani http://www.full-race.com/catalog/popup_ ... hp?pID=259
Merge collector is a Burns Stainless 4 into 1, Robotically TIG welded 321 Stainless 1.5" tube into a very low angle merge pipe with an exit of 2.5" with a 316 stainless Tial VBand flange tacked on. http://www.burnsstainless.com/mergecollectorsmain.aspx
http://www.burnsstainless.com/mc4-163-16-321.aspx
These are $350 by themselves
Flange can be easily removed and replaced with any other turbo inlet flange.
Ideally suited to the IHI 3 bolt pattern circular inlet flange (also available if required)
Also available IHI 5 bolt turbo exhaust outlet, also in 316 10mm laser cut stainless.
http://s40.photobucket.com/albums/e221/bewsh/mani/
jc..
Post by jc.. » Mon Sep 06, 2010 9:34 am
ends on thursday
Users browsing this forum: Google [Bot] and 73 guests
