BM Town Front LED units for B7?
RS4-Chew
Post by RS4-Chew » Sat Jul 31, 2010 9:43 am
It was only a matter of time before it was mentioned...
anyone took the plunge with LED DRL units for the fronts from BM Town?
Ive seen several DIY LED mods etc but just wondered if anyone has any further info/pics/opinions on them
see below pic (from BMT website)
may be a bit OTT especially with LED rears - cant make my mind up, especially not from one lowish res pic.
to clarify - Im referring to the main lamp unit not the lower LED strips!
discuss :wink:
07/57-B7 RS4 Saloon-Sprint Blue,Tech Pack, DRL's,Bluetooth,Carbon Trim,Chrome Optics,Sunroof,open zorst flaps,FBSW,Bose,Buckets,New Boots,R8 alu oil cap,BMC panel,RS plate,Fresh plugs,10mm Rear H+R spacers courtesy of Virdee.
Also - 1970 MGBGT for Hillclimbing and Sprint racing
03/53 - MK4 Deep Blue Pearl R32 3 door (sold)
"You never hear a truer word spoken in jest"
seventeenAPG
Re: BM Town Front LED units for B7?
Post by seventeenAPG » Sat Jul 31, 2010 10:21 am
RS4-Chew wrote:It was only a matter of time before it was mentioned...
discuss :wink:
I will not go with them but what I would like if BM had LED bulb to replace our existing running light bulbs. They seem just like a rear tail light bulb so theres bound to be a replacement . If we can get number plate bulbs (which I am ordering today) then we should be able to bet new running light bulbs, right?
RE: Re: BM Town Front LED units for B7?
Post by HYFR » Sat Jul 31, 2010 11:38 am
the problem with aftermarket from lights is they are crap. The are not bi xenon and not adaptive...
Aftermarket rears are good because OEM are so basic
P_G
Post by P_G » Sat Jul 31, 2010 3:58 pm
+1
scaghead
Post by scaghead » Sun Aug 01, 2010 5:41 am
+2
seventeenAPG
Post by seventeenAPG » Mon Aug 02, 2010 11:50 am
discuss :wink:
I took out one of the DRLs and it is a regular 12v 21w bulb. Have asked BM if we can get LED version and also LED rear indicator bulb. These I will change but I will def not go with the front LED strip.
PetrolDave
Post by PetrolDave » Mon Aug 02, 2010 2:16 pm
17-APG wrote:I took out one of the DRLs and it is a regular 12v 21w bulb. Have asked BM if we can get LED version and also LED rear indicator bulb.
You need a LED bulb that takes as much current as a normal bulb (often done with an additional resistor in parallel), otherwise the bulb failure warning will go off.
P_G
Post by P_G » Mon Aug 02, 2010 2:24 pm
Not the most intrcate either, those with LED DRL's have to locate the resistor in the headlight housing and often in the access cap or outside of it attached to bodywork with wires running into the headlight unit.
Not a particularly easy job but can be done. Also you have the get the right resistor; some reported the resistor getting so hot it melted the headlight access cap!
PetrolDave
Post by PetrolDave » Mon Aug 02, 2010 2:26 pm
P_G wrote:Also you have the get the right resistor; some reported the resistor getting so hot it melted the headlight access cap!
the resistor needs to make an approx 1W LED take enough current to "fool" the bulb failure system that it's a 21W bulb - so the resistor has to dissipate 10-20W, so it's gonna get hot.
MB2
Post by MB2 » Mon Aug 02, 2010 2:34 pm
17-APG wrote:If we can get number plate bulbs (which I am ordering today) then we should be able to bet new running light bulbs, right?
Let us know how you get on with the numberplate bulbs as the ones I tried (complete units made by "racing dash") triggered bulb out warnings so I don't think the Rashing Dash ones work with the colour DIS.
APM
Post by APM » Mon Aug 02, 2010 9:26 pm
why would you want main lamp units like this on an Rs4?
RS4-Chew
Post by RS4-Chew » Tue Aug 03, 2010 12:34 pm
"I" wouldn't - just a topic of discussion as we were on about rear LEDs in another thread :beerchug:
seventeenAPG
Re: RE: Re: BM Town Front LED units for B7?
Post by seventeenAPG » Wed Aug 04, 2010 11:05 am
RS4-Chew wrote:"I" wouldn't - just a topic of discussion as we were on about rear LEDs in another thread :beerchug:
Well, just to update everyone, BM are getting me LED bulbs which will hopefully be a direct replacememnt for the standard 12V21W bulb that is used for this ( I took one out to check at weekend) I will let everyone know when I get them.
I am also getting LED indicator bulbs that light up orange to fit into my new LED lamp clusters. Again, will let you know how they look and work...
P_G
Post by P_G » Wed Aug 04, 2010 11:45 am
Will they have a built in resistor or is it an in parallel i.e. dangling on a wire resistor?
sonny
Post by sonny » Wed Aug 04, 2010 1:02 pm
I think that front end looks awful
Users browsing this forum: Bing [Bot] and 214 guests
