I won't insult you, re: 'tool', but is LESS than 0.1%, considerable less...rs4v8 wrote: It is 0.1% ya tool!! It's you that made an arse of yourself by not reading my post properly!! If you read it why give me the donkey maths lesson then eh?![]()
DRC Recall in US/Canada
a man of reason...
road conditions have much to do with it, as I suspect right hand drive does...
US roads are generally good in rural areas, less so in urban...
and of the few DRC failues most have been in the cities...
the shocks face a substantial service duty:
heavy car, assume and average load of 2 ~4400 lbs
60% on front ~1300/wheel, or for a better balanced car ~ 5200 lbs net
add the quattro torque load and large brakes and you get the point...
(Spain scored!!!!!)
add in system complexity, 170 to 200 psi operating pressure and a non-compressible fluid (as opposed to gas shocks) and they will wear faster..
what is an acceptable life span?guys who buy the Stasis sytem have to rebuild annually...
perhaps our expectations are unrealistic to some degree...
(Spain scored!!!!!)
PetrolDave wrote:Audi engineers extensively test on German roads - which are (mostly) billiard table smooth so they will not have seen any DRC issues.
The problem isn't engineering, it's the "bean counters" who prevent the engineers from testing under global road conditions to both limit costs and meet (too) tight launch schedules. Ask any engineer working for any European company - they'll tell you exactly the same thing.
UK test site such as Millbrook have roads to simulate Belgian pave and US manholes, so it IS possible to test under global road conditions in Europe - contrary to what the "bean counters" think.
P.S. The shock absorbers on my wife's Skoda need replacing after only 25,000 miles - at least the shock absorbers on my RS4 lasted 44,000 miles...
that's why they are excluded from warranty (until a special one was offered) they are considered a wear/tear item, and Audi has no control over how they are used...or where...Sims wrote: Fit for purpose for the market the product is sold in, -Death valley or Alaska, Autobahns or Hackney.
As an aside, did Audi use UK roads to develop the suspension system for one of their cars?
if you blow a tire/bend a rim in a pothole Audi should pay?
whose to say the failures are a result of impulse loading?
I would like to see a correlation between DRC failure and rim replacement, lol
there are many cars with >50k miles with no issues...
normal shocks generally have reached 50% life at 25k miles, and degrade rapidily after that
talk about condescending AND simplistic...Sims wrote: That's a simplistic view, times have changed.
times have changed?
really? you mean time doesn't stand still?
the clock keeps ticking?
you guys won't see this recall, sorry, but them are the facts...
you did not see the RS6 one either...
did you get the 100k M3 engine warranty?
NIKKIrsSIXX
- 1st Gear
1. Less than 1% of B7 RS4 cars have DRC failure-Complete utter rubbish, Sorry 'trash'. Do the 'Math'.
2. No amount of clever sums will get away from the FACT that it is 25%+ of all B7 cars that suffer this sub 50k.
3. I know all this yet I will still use this car as Audi have warrantied it well and at the end of the day it is a bloody good car.
- northernpar
Chose not to post on the site for a while due to all the bullshit arguments but generally came by for a lurk now and again. Saw this post and as my DRC appears to have gone south again thought I'd post up the info. Read all the thread and see it has decended into the normal bullshit arguments...........again. So I'll keep it short, sweet and objective.
Car rattling around like a shopping trolley with a stuck wheel. Oversteer turning left, understeer turning right. SS+ fitted but OSR sitting around 1/2 lower than NSR (arch to road) also NSF sitting different height from OSF. Car booked in for 16th for assessment/repair under warranty. Will press dealer on AoA stance to see what Audi UK are saying regards the 4 corner 3G repair. If it's 'no dice' then I guess its the 5Y/75K option and then coilovers.
Will post once any information available. In the meantime you guys can carry on with the 'pissing contest'. Me? I'm off to do something more constructive with whatever time I have left on this planet.
Over and out.
Over and out.
1. LESS than 1%, considerablyNIKKIrsSIXX wrote:1. Less than 1% of B7 RS4 cars have DRC failure-Complete utter rubbish, Sorry 'trash'. Do the 'Math'.
2. that is not FACT, only Audi knows the numbers, but from what has been posted, <1%
3. agreed
The only sensible thing you've said.ArthurPE wrote: 2. that is not FACT,
Where do you mean? posted where? on the fault log? Your argument is that the failure rate is <1% overall, IN THE WORLD....... is this a new tune we're hearing? It's either that or you are seriously saying that the 133 posts on the fault log are the ONLY ones in the whole world. and that my friend just can not be the case.ArthurPE wrote:but from what has been posted, <1%
Current
'10 Nissan GT-R Black Edition, Kuro Black.
'59 Scirocco 2.0 TFSI
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'07 RS4, Phantom black saloon
'57 Clio 197
'04 Aprilia RSVR Factory. Black.
E46 M3 SMG, Alpine white
E46 320i coupe
E36 328is coupe
VW golf VR6
Screw you guys!' - Eric Cartman
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'57 Clio 197
E46 320i coupe
E36 328is coupe
VW golf VR6
Makes a change. Your point is MOOT regardless.ArthurPE wrote:I won't insult you.
Current
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'57 Clio 197
E46 320i coupe
E36 328is coupe
VW golf VR6
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'57 Clio 197
E46 320i coupe
E36 328is coupe
VW golf VR6
It was a 100% no-go three weeks ago when mine packed in again. Indeed, they replaced only one as the other rear one "held a pressure test". I strongly suspect it will be in for the final original shock when it dies soon. They were very apologetic when I suggested the final one might very well go next week and that I was under the impression they should be changed in pairs, but this policy came from Audi UK HQ as they had checked before doing the work.northernpar wrote: Will press dealer on AoA stance to see what Audi UK are saying regards the 4 corner 3G repair. If it's 'no dice' then I guess its the 5Y/75K option and then coilovers.
Current
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'57 Clio 197
E46 320i coupe
E36 328is coupe
VW golf VR6
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'57 Clio 197
E46 320i coupe
E36 328is coupe
VW golf VR6
Where are the FACTS to say it is 25%+? Do you have a report from Audi AG based on an assessment compiled from all the production RS4's that were built by them of how many have DRC failure?NIKKIrsSIXX wrote:2. No amount of clever sums will get away from the FACT that it is 25%+ of all B7 cars that suffer this sub 50k.
If so please share as I imagine we would all be interested to see the figures.
He's got you there NIKKIrsSIXX!!P_G wrote:Where are the FACTS to say it is 25%+? Do you have a report from Audi AG based on an assessment compiled from all the production RS4's that were built by them of how many have DRC failure?NIKKIrsSIXX wrote:2. No amount of clever sums will get away from the FACT that it is 25%+ of all B7 cars that suffer this sub 50k.
I am still curious to know how certain people are so confident that it's it's been proven to be <1% worldwide when all the evidence we do have suggests otherwise.
Current
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'57 Clio 197
E46 320i coupe
E36 328is coupe
VW golf VR6
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'57 Clio 197
E46 320i coupe
E36 328is coupe
VW golf VR6
NIKKIrsSIXX
- 1st Gear
Users browsing this forum: Google Adsense [Bot] and 265 guests
