boostgauge
zsivany
boostgauge
Post by zsivany » Sun May 30, 2010 7:38 pm
guys i am busy installing a boostgauge on my rs6.
but struggling to find a boost pipe where i can connect the t-piece for the gauge?
anyone has done this before?
RE: boostgauge
Post by bam_bam » Sun May 30, 2010 8:01 pm
What is the point of a boost gauge? *wraps arms over head and runs for cover*
pete2144
Re: boostgauge
Post by pete2144 » Sun May 30, 2010 8:02 pm
zsivany wrote:guys i am busy installing a boostgauge on my rs6.
I used one of the diverter valve pipes.
HTH
ElevenSec
Re: boostgauge
Post by ElevenSec » Tue Jun 01, 2010 4:52 pm
Zsivanny:
Best place to tap into is the line to the fuel pressure regulator. located below the air filter box. Remove the box, the regulator is located on the top left. Remove the short hose install Tee and your good to go. Do not tap into the diverter valve lines. They use some kind of an independent vacuum system. Hope this helps.
zsivany
RE: Re: boostgauge
Post by zsivany » Thu Jun 10, 2010 10:24 am
hey vintron. thanks for the picture. i have tried that pipe but i got no boost?
maybe i was going something wrong? so i tapped into the dv pipe.....
but i only get boost on 1 side now?
is your gauge working fine? how much is your car boosting?
also what should a stock and a chipped rs6 boost?
thanks again
ElevenSec
Re: RE: Re: boostgauge
Post by ElevenSec » Thu Jun 10, 2010 7:37 pm
zsivany wrote:hey vintron. thanks for the picture. i have tried that pipe but i got no boost?
thanks again
Hi Zsivany:
There definitely should be no issues in tapping into the Fuel Pressure regulator vacuum line. There really isn't much margin for error there. So I would try it again and check your connections carefully. Stock max boost pressure I believe is around .8 bar (11.6 psi). I am running a MTM remap, which seems to max out at about 1.2 bar (18 psi). I am using a VDO mechanical boost-vacuum gauge. It works fine for me. I could not find any place to mount it, so I attached it to the drivers side A pillar. Not the best looking, but its functional. Hope this helps.
drybeer
RE: Re: RE: Re: boostgauge
Post by drybeer » Thu Jun 10, 2010 8:19 pm
Is there not an add on for the DIS advertised somewherenwhich let's you show boost in the DIS or on the RNS-E screen?
If so it would make a much more subtle mod IMHO...
C7 A6 allroad 3.0TDi.
Tiguan 2.0TDi R-line
zsivany
Post by zsivany » Thu Jun 10, 2010 8:45 pm
thanks guys for all the info. gonna try to connect to the fpr pipe and let u know! :-)
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot] and 200 guests
