I have just got an S4 cab with Audi dvd sat nav. Sometimes it doesnt find any satelites and then the sat nav then just locks on to any road the arrow happens to come across.
Any clues as too what might be causing this, where about is the gps located on a cab?
Steve
Cabriolet Sat Nav problems
RE: Cabriolet Sat Nav problems
Get it scanned for Nav faults is easiest. Could be something as small as an unplugged GPS antena
Re: RE: Cabriolet Sat Nav problems
Cheers. I will drop by a garage & ask them to plug their diagnostics in.xyber wrote:Get it scanned for Nav faults is easiest. Could be something as small as an unplugged GPS antena
Hi,
If you press the "Nav-Info" button when viewing the map it should tell you how many satellites are receivable. I had a similar problem with my Cab where the Sat Nav would wander off across fields - it turned out to be a break in the cable near the boot hinge. The sat nav worked fine with the boot up , but not with it down. I cut the cable where the break was and soldered in a length of repair cable.
Regards, Chris.
Regards, Chris.
Users browsing this forum: No registered users and 61 guests
