580PS RS6
Doug_S2
Trader (Expired)
580PS RS6
Post by Doug_S2 » Sat May 08, 2010 5:37 pm
Bolt on Hybrids, Manifolds, full exhaust and Wagner ICs.
More can be had if intake temps were lower on the dyno - better ICs or water injection.
Don't expect more torque than a tuned rs6 as it is held back a lot. It pulls hard to high revs. It will pull to 7k - just got the gearbox chip to tweak to do that.
http://www.MRCtuning.com
grizz
RE: 580PS RS6
Post by grizz » Sat May 08, 2010 5:39 pm
well done mate. Is that your's ..
Unit 20
0151 3366888
Doug_S2
Trader (Expired)
RE: 580PS RS6
Post by Doug_S2 » Sat May 08, 2010 5:47 pm
It is hers.
grizz
RE: 580PS RS6
Post by grizz » Sat May 08, 2010 5:51 pm
haha , you know what i meant .. Would it make more with stage 2 hybrids ..?
Unit 20
0151 3366888
Doug_S2
Trader (Expired)
RE: 580PS RS6
Post by Doug_S2 » Sat May 08, 2010 6:02 pm
These are the k06 wheel hybrids with hotside mods so I doubt there is more to be had out of these flow wise. Just a manual box will make it feel better!
Re: RE: 580PS RS6
Post by chunky79 » Sat May 08, 2010 6:06 pm
Doug_S2 wrote:These are the k06 wheel hybrids with hotside mods so I doubt there is more to be had out of these flow wise. Just a manual box will make it feel better!
so when you changing the box then :D
Doug_S2
Trader (Expired)
RE: 580PS RS6
Post by Doug_S2 » Sat May 08, 2010 6:11 pm
The manual car on wastegate boost feels a LOT faster
Doug_S2
Trader (Expired)
Re: RE: 580PS RS6
Post by Doug_S2 » Sat May 08, 2010 6:12 pm
She likes the auto.
ecain63
RE: Re: RE: 580PS RS6
Post by ecain63 » Sat May 08, 2010 6:12 pm
Good show doug. Always pushing the boandaries.
Now Sold!
'03 Daytona Grey RS6 Avant.
275 Vreds.
MRC custom map with TCU.
Miltek Resonated.
Hi Flow filters.
19" 'Plus' (Grey) rims.
Golffather
Post by Golffather » Sat May 08, 2010 7:37 pm
Fantastic, pushing the boundaries as always
Well done!
spurtle
Post by spurtle » Fri May 14, 2010 9:56 pm
What's wastegate boost?
RS6 Avant (C5), Daytona grey
Gone but not forgotten: S4 Avant (B5)
S2tuner
Trader (Expired)
Re: RE: Re: RE: 580PS RS6
Post by S2tuner » Fri May 14, 2010 10:04 pm
spurtle wrote:What's wastegate boost?
Mechanical boost as provided by the wastegate springs only, i.e. ECU boost control circuitry "disconnected".
paul_23
RE: Re: RE: Re: RE: 580PS RS6
Post by paul_23 » Mon May 17, 2010 10:50 am
So what is the boost measured then? I reckon it would need to be 1.2-1.3 bar at peak to get these figures (?) but can these hybrids hold that boost for the full rev range as I notice the torque curve drops off after 4700?? Have you changed the head gaskets as I think the MTM stage 4 580hp conversion changes these.
650RS
Post by 650RS » Fri May 21, 2010 8:08 am
I would also like to know the boost pressure across the rev range. I am fairly confident if the OEM actuators are retained and unmodified the boost will be at most 0.9bar at redline.
Turbo dyanamics in the UK is who will be performing the upgrade on my turbos with the addition of custom made actuators with a base pressure of 0.8-1.0bar compared to the 0.4bar the OEM units.
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sat May 22, 2010 8:18 am
the torque drop off is not as severe as the graphs shows - the lower scale of torque on the right side does not start at 0.
boost isn't everything and we try to make the engine as efficient as we can instead of forcing it. We use tubular manifold, good exhaust, thick headgaskets, better ICs and the next stage is a better intake system to test to get it higher.
Users browsing this forum: No registered users and 560 guests
