19" alloys
paulyd65
19" alloys
Post by paulyd65 » Thu May 06, 2010 12:35 pm
Hi All,
Just a quick questions. Will 19" alloys fir on my S4 B6?
I know that the OEM RS4 alloys don't work because they are too wide but just wondered if the actual 19" diameter was a problem with rubbing on arches, etc.
Cheers.
Paul.
xyber
RE: 19" alloys
Post by xyber » Thu May 06, 2010 6:33 pm
I've got 19x9 ET41. Fits perfectly. No rubbing ever
RS4 wheels don't work because they are a low offset so push the wheels outward to fill the wide RS4 arches
1781cc
RE: 19" alloys
Post by 1781cc » Thu May 06, 2010 10:11 pm
http://www.rs246.com/index.php?name=PNp ... highlight=
235/35/19 on an ET 35 offset. the PCD is 112...
no rubbing or anything, lovely!
paulyd65
Post by paulyd65 » Fri May 07, 2010 10:24 am
Cheers Chaps. Off to surf the web to get me some 19"
xyber
Post by xyber » Fri May 07, 2010 7:16 pm
Mine is lowered at fair bit on KW V3s aswell, forgot that bit
it's bedded in now so dropped abit more than those pics
R23
Post by R23 » Sat Aug 14, 2010 11:43 pm
wots the ride lo=ike on 19's?
1781cc
Post by 1781cc » Sun Aug 15, 2010 7:06 am
absolutely fine, a little harsher at first because of the cheap bundled tyres, but when you get back to decent boots it settles again. certainly feels sturdier, like there is less sidewall flex as you corner or drift.
iR8V10
Post by iR8V10 » Sun Aug 15, 2010 9:05 am
How about my oem 19x9 et35 rs6 wheels in gunmetal. See my sig...
xyber
Post by xyber » Sun Aug 15, 2010 7:52 pm
RS6_Dave wrote:How about my oem 19x9 et35 rs6 wheels in gunmetal. See my sig...
Yep, they'll go on with the right tyres, slightly stretched like mine. Basically the same as fitting 5mm spacers to mine, which I'm considering doing
Thacker
Post by Thacker » Tue Aug 24, 2010 3:14 pm
You can go bigger on the wheel diameter as long as you drop down on the profile size of the tyre, so the overall diameter of the wheel and tyre are the same or similar.
I have a calculator file somewhere if required?
Users browsing this forum: No registered users and 199 guests
