Bluetooth & iPhone - keeps disconnecting and reconnectin
rjkflyer
Post by rjkflyer » Tue May 04, 2010 3:14 pm
As of a few days ago, I have the above problem. Bloody thing chimes connected and 2-3 mins later it chimes disconnected. A few more mins and connected again. Then disconnects. Does this continuously.
Cannot seem to call out either - it says 'connecting' then chimes disconnected. Have rebooted/reset etc etc.
Now, tried a trusty old Nokia 6310i and seems to work faultlessly with same SIM.
However, Jawbone headset seems to work OK with iPhone, so it's not clear what's wrong here.
Any thoughts/experience/cures?
RS4KILLA
RE: Bluetooth & iPhone - keeps disconnecting and reconne
Post by RS4KILLA » Tue May 04, 2010 3:16 pm
had the same problem recently
B5 S4 KO'4 black saloon sunroof......
B5 RS4 Goodwood Green,sunroof, nav tv, short shifter,
B5 S4 Nogaro saloon
B5 S4 Black saloon,
B5 RS4 Misano red,
B5 RS4 noggy blue,
B7 RS4 Sprint Blue.
B5 RS4 avus silver
pad125
Re: RE: Bluetooth & iPhone - keeps disconnecting and rec
Post by pad125 » Tue May 04, 2010 3:23 pm
RS4KILLA wrote:had the same problem recently
Me too, changed the handset and all good now.
rjkflyer
RE: Re: RE: Bluetooth & iPhone - keeps disconnecting and
Post by rjkflyer » Tue May 04, 2010 3:29 pm
Hmm, so despite headset working correctly, you suspect iPhone not Audi BT module?
pad125
Post by pad125 » Tue May 04, 2010 3:36 pm
I had the guys change the module and it made no differance, changed the handset and all ok
lengster1
Post by lengster1 » Tue May 04, 2010 3:37 pm
Ive had the same happen in the last few weeks also!
binder
Post by binder » Tue May 04, 2010 3:58 pm
I've had the same happen on several occasions (with a 6310i incidently) I eventually get it back after several "deleting old phone and starting from scratch attempts" but have not found a definitive cure.
basilbrush
Post by basilbrush » Tue May 04, 2010 10:15 pm
Very interesting to read this! I also have exactly the same issue with my iPhone 3gs and my bluetooth module, I was thinking that it maybe the handset thats faulty rather than the module! do you also sometimes get really bad feedback noises just before a call connects when dialing out? im going to try and get my iPhone replaced and will then let you know if its fixed the issue!
Avus B7 RS4 Saloon
Users browsing this forum: Google Adsense [Bot] and 85 guests
