airbox flap
garym
airbox flap
Post by garym » Sat Apr 24, 2010 8:34 am
what does it do ? how does it work? what if i remove it? anyone ?
P_G
Post by P_G » Sat Apr 24, 2010 9:05 am
At somewhere between 5 and 5.5k rpm it opens to allow more air into the engine giving you the shove in the back that most experience at that level of revs. It is vacuum actuated IIRC.
caldy has removed his air box flap, not sure if there is a discernable difference? I'm sure he could answer better.
garym
Post by garym » Sat Apr 24, 2010 9:43 am
mines missing inacceleration before 3400 let alone 5000,has anuone had problems with injectors? feels like holding back/no fuel
PetrolDave
Post by PetrolDave » Sat Apr 24, 2010 7:02 pm
garym wrote:mines missing inacceleration before 3400 let alone 5000,has anuone had problems with injectors? feels like holding back/no fuel
Any fault codes stored in the engine ECUs (addresses 1 and 11)?
garym
airbox flap
Post by garym » Sat Apr 24, 2010 9:31 pm
no nothing showing no lights on
tartan_rob
RE: airbox flap
Post by tartan_rob » Sun Apr 25, 2010 11:23 am
I have takne mine out and there is more induction noise. I did it at same time as fitting a K&N panel filter and the car revs better at high revs. Engine note much improved.
2017 Kawasaki Z1000
2014 RS6
2014 S1
sonny
RE: airbox flap
Post by sonny » Sun Apr 25, 2010 11:51 am
When I had my GruppeM induction kit fitted, the so called "Boost" was apparent across the whole rev range (more or less from from what I can remember), however it was not so apparent at 5500rpm. @Porky can you confirm this is the same for you seeing as you now have the GruppeM fitted?
PetrolDave
Re: airbox flap
Post by PetrolDave » Sun Apr 25, 2010 7:09 pm
garym wrote:no nothing showing no lights on
No light on doesn't mean no fault codes stored, have you looked with VAG-COM?
garym
airbox flap
Post by garym » Sun Apr 25, 2010 9:31 pm
not lately .its always been to main dealer and they say every time no faults but it cant be right it drives like a peice of crap
RE: airbox flap
Post by HYFR » Sun Apr 25, 2010 9:35 pm
take it to a specialist....MRC ?
chaucer
RE: airbox flap
Post by chaucer » Mon Apr 26, 2010 11:24 am
Air filter flap seized and solenoid valve under o/s headlight swollen/split fault codes will not be stored ,check for vac pipe not squashed under bulk head
Users browsing this forum: Google Adsense [Bot] and 210 guests
