airbox flap
airbox flap
what does it do ? how does it work? what if i remove it? anyone ?
- PetrolDave
airbox flap
no nothing showing no lights on
tartan_rob
RE: airbox flap
I have takne mine out and there is more induction noise. I did it at same time as fitting a K&N panel filter and the car revs better at high revs. Engine note much improved.
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
RE: airbox flap
When I had my GruppeM induction kit fitted, the so called "Boost" was apparent across the whole rev range (more or less from from what I can remember), however it was not so apparent at 5500rpm. @Porky can you confirm this is the same for you seeing as you now have the GruppeM fitted?
- PetrolDave
Re: airbox flap
No light on doesn't mean no fault codes stored, have you looked with VAG-COM?garym wrote:no nothing showing no lights on
airbox flap
not lately .its always been to main dealer and they say every time no faults but it cant be right it drives like a peice of crap
RE: airbox flap
take it to a specialist....MRC ?
RE: airbox flap
Air filter flap seized and solenoid valve under o/s headlight swollen/split fault codes will not be stored ,check for vac pipe not squashed under bulk head
Users browsing this forum: Zyox and 234 guests
