Advice required on possible suspension problem!!
Stealth_RS4
Bit of a problem. Got my tyre changed today and was having a look around the car when I noticed the car is sitting lower on the passenger rear than the drivers rear. About an inch and a half in the difference. I have sports suspension plus by the way. Pics to follow.Anyone shed any light on the problem. Checked the suspension on that side too, cant see any weeping etc. Back drivers gap between tyre and arch seems to be higher than the drivers front wheel arch gap.
Stealth_RS4
RE: Advice required on possible suspension problem!!
after driving the car measure from level ground to fender lip at each corner...
mine are ~26.5" +/- 1/8"
an 1.5" variation sounds like a problem...
which tire was changed?
perhpas the spring isn't situated properly in the perch?
maybe got out of wack when jacked up for the tire?
Stealth_RS4
Passenger rear was changed today. From looking at pics of the car from a couple of years ago it looks like maybe the drivers side rear is up to high. Should sit slightly lower at the back with sports suspension plus? How would I check the spring Arthur?
Re: RE: Advice required on possible suspension problem!!
you have to get under it, see if both sides components look the same, ie, symetrical...nothing different, bent, etc.Stealth_RS4 wrote:Passenger rear was changed today. From looking at pics of the car from a couple of years ago it looks like maybe the drivers side rear is up to high. Should sit slightly lower at the back with sports suspension plus? How would I check the spring Arthur?
how far was the car driven after the tire change until the measurments?
time to settle?
Stealth_RS4
RE: Re: RE: Advice required on possible suspension problem!!
About an hour. Ill go out now and take off the drivers side rear wheel to have a look.Fender to ground measurement there is 28inches!
Re: RE: Re: RE: Advice required on possible suspension probl
yep 1.5 or so inches too high...Stealth_RS4 wrote:About an hour. Ill go out now and take off the drivers side rear wheel to have a look.Fender to ground measurement there is 28inches!
what's the other side?
take some pics and be very careful
RE: Re: RE: Re: RE: Advice required on possible suspension p
Have you ever had your DRC changed out? lets hope they put back SS+ instead of the Norm suspension (worse case scenario of course). did you say the car had only just started to sit this high after the tyre change, or you have only just noticed it, when compared to older pics?
Angelo_Amato
- 1st Gear
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot] and 180 guests
