new years first problem :)
2.2 I5 20v turbo - 315 bhp
timucin
Post by timucin » Fri Jan 02, 2004 12:38 am
happy new year everybody
[img]images/graemlins/biggrin3.gif[/img]
1-1-2004 and my first performance problem;
i started not to take them very serious cause i face one every week [img]images/graemlins/smile.gif[/img]
now:
-turbo stalls ; i check from pressure gauges, it stalls sometimes up to 20 seconds...
what can be wrong?
Quattro
timucin
Re: new years first problem :)
Post by timucin » Fri Jan 02, 2004 1:36 pm
here is my problem:
first gear it accelarates ok but when i pull it to second it stalls. it doesnt keep on accelerating as it should.. but if i wait like 4-5 second s when i pull it to second then it accelarates normal?
what can this mean?
Quattro
Jani
Post by Jani » Fri Jan 02, 2004 4:36 pm
Read fault codes first (vag-com or dealership 1551/1552). The motronic is taking away boost, and you'll have some clue to the cause by looking at the codes.
I suspect a leak in the intake somewhere, but who knows.
timucin
Post by timucin » Fri Jan 02, 2004 6:11 pm
i still didnt receive my vag-com package
will take it to service on monday
[img]images/graemlins/frown.gif[/img]:(
Quattro
Greg_S
Post by Greg_S » Sat Jan 03, 2004 12:47 am
Have you checked all of the intake hoses and vacuum tree?
IS it like hitting a brick wall whengets to about 4k revs?
Bullshit baffles brains
NIKOLAS
Post by NIKOLAS » Sat Jan 03, 2004 1:52 am
Happy new year everybody.
Hey Timusin for the last few days i am getting a similar problem. I dot get full boost on 1 2 3 gear but i do in 4 even though the car seems like loosing or cutting the boost at 1.4. ( Normally i should get 1.8 bar.) It feels like there is a cut in the fuel or spark problem. I dont think it is a leak in boost because the engine seems like hesitating for a moment due to either cut in the fuel or one of the cylinders not working for a moment.nyway i ll check it on monday since everyone is on holidays now.
What did you do with the brake light? I changed the pads but i stil get and now even more often. I ll check the warning valve on monday. Did you get rid of yours false brakelight warning? ( Note that the level of brake fluid is ok i.e full)
Ps: Sometimes i think that the problems will never end.On the other hand it gives me such a smile when late at night ( most of the times after a lot of alcohol! [img]images/graemlins/tongue.gif[/img] ) it drives like hell through slippery turns here i our poorly constacted Cretan roads. Anyway with the money i ve spent on the car and the money i am planning to spend i could buy a new EVO 8. The thing is that you fall in love with it just like a demanding girlfreind that in one time you want to get rid of and the other you feel that you cant live without.
kEEP THE FAITH. NICKK
timucin
Post by timucin » Sat Jan 03, 2004 2:22 am
there is more: on higher gears boost drops to 5-6psi at 5000rpm exactly. it shows 20 psi at normal conditions.this is protection mode but i dont know what is wrong,will check fault codes tomorrow
Quattro
timucin
Post by timucin » Sat Jan 03, 2004 2:26 am
didnt solve my brake light problem,its still there , i did the brake pedal -bomb test , yes it turns to stone after 7-8 pumps (it says under 10 pump change it for sure)
dunno what to do for the moment.....
Quattro
Greg_S
Post by Greg_S » Sat Jan 03, 2004 12:44 pm
brake bomb is definetly worth changing. As for your cutting out and low boost problems.
Has the WGFV and DV been replaced recently? If not would do that, WGFV is about £25, DV £35.
Also worth checking is the wastegate since this may be sticking slightly. Since it is controlled by the ECU thru the WGFV that could still be the problem.
Have a read thru the info here too
SJM Autotechnik troubleshooter
timucin
Post by timucin » Sat Jan 03, 2004 1:12 pm
yep i ve read that site.
need a vag-com asap but coulndt find any today,still waiting the one i order. services are closed today,will wait monday to see whats wrong..
thnx for help
Quattro
Return to “RS2 (B4) 1994-1995”
Users browsing this forum: Google Adsense [Bot] and 69 guests
