S4 exhaust modification
nihc
Post by nihc » Tue Feb 16, 2010 1:29 pm
Glen wrote:got the engine light turned off no probs they also left one sensor unplugged... I had the car on the rolling road while i was there and it only made 270bhp! 100 less than i was expecting! He said it was common for s4's to under power and there was no problems WTF? Cant be right can it?
Hi, it doesn't sound good. Is that wheel horse power or corrected for crank?
You should be making that at the wheels. S4's don't tend to underpower, either his RR is shot or your car has a problem :(
He shouldn't have left a sensor unconnected. Am I right in thinking that you have new downpipes with one sport Cat on each bank?
Glen
Post by Glen » Tue Feb 16, 2010 2:22 pm
yeah that was at the fly wheel :( going to book into mrc when i return from hols.
BlingBling
Post by BlingBling » Tue Feb 16, 2010 3:23 pm
Glen wrote:the other was the front engine mount which a mechanic told me was common wrong reading???
How can i tell if the engine mount has actually gone?
Either visully, they leak, or with VAGCOM. Not sure about them giving a wrong reading but they can be a weak point.
BlingBling
Post by BlingBling » Tue Feb 16, 2010 3:25 pm
nihc wrote:He shouldn't have left a sensor unconnected. Am I right in thinking that you have new downpipes with one sport Cat on each bank?
If his set up is the same as mine then you are correct. The sport cats replaced the main cats and the pre-cats have been deleted.
Glen
Post by Glen » Wed Feb 17, 2010 6:05 pm
Just managed to get Vagcom to work and came up with these faults
Have reset codes now to see if they all come up again.
BlingBling
Post by BlingBling » Wed Mar 03, 2010 9:53 pm
^Did you get the car sorted?
Glen
Post by Glen » Sun Mar 07, 2010 9:41 am
Its going into fountain Audi Tuesday for engine mount, MOT and service and then of to MRC on thursday for a health check and custom map... going to be an expensive week :roll:
BlingBling
Post by BlingBling » Sun Mar 07, 2010 7:13 pm
Good luck.
Glen
Post by Glen » Thu Mar 11, 2010 11:58 pm
Well after a day in MRC i can safely say it was all worth the effort and £££ the S4 is perfect!
So much more fun, pulls from much lower down and goes like stink!
And the noise... Also perfect just like the great clips on you tube which made me want one in the first place. :D
BlingBling
Post by BlingBling » Fri Mar 12, 2010 4:41 pm
Glen wrote:Well after a day in MRC i can safely say it was all worth the effort and £££ the S4 is perfect!
I knew you would be pleased. Do you intend to go for another RR?
Glen
Post by Glen » Sat Mar 13, 2010 12:00 pm
Was thinking about it, but may just wait for MRC to have there's fitted.
linkman72
Re: S4 exhaust modification
Post by linkman72 » Fri Sep 21, 2012 6:32 am
millteks are a blatant rip off and I wouldnt touch them unless they start charging <£700 for their systems, I have had 3 powerflow exhausts on other cars in the past and apart from a boomy job on my Jetta Gti ( right on 60mph cruising the car would fappin vibrate !! ) they have been fine, they have quoted me £750 for a cat back and thats excellent for a custom job, only thing is I cant find anyone who has had their B6 done at powerflow and just to add is their anypoint in trying decat pipes or will that screw the ecu ??
linkman72
Post by linkman72 » Fri Sep 21, 2012 7:16 am
nihc did you ever get a recording of your AAS system because my old sierra had a pair of manifolds they made a few years ago and the quality was spot on
they are not far from me so they could be an alternative to powerflow ( on scotsy road )
cobraBLACK
Post by cobraBLACK » Sat Sep 22, 2012 3:02 pm
linkman72 wrote:...they have quoted me £750 for a cat back...
You can get a Milltek for that - a system that's been designed with R&D specifically for the car.
Audi S4 Avant (B6, 2004) in Goodwood Green.
Post by Ian_C » Sat Sep 22, 2012 3:06 pm
I love my Milltek, best mod on the B6 bar none, wouldn't and couldn't be without
