led side lights
johnny11
Re: RE: Re: led side lights
Post by johnny11 » Sun Feb 14, 2010 7:04 pm
MoRS6+ wrote:
johnny11 wrote:.
Hehe. That'll be me. Next to Phil's, mine looked like candles! Or a torch with a normal bulb and half-used batteries.
yep thats what done it for me, was really so much difference,
did you get your back window done after all?
MoRS6+
Post by MoRS6+ » Sun Feb 14, 2010 11:14 pm
johnny11 wrote:
MoRS6+ wrote:
johnny11 wrote:.
Nah not yet. Window still gets stuck going back up. Been a bit busy with work. Must try to find that Youtube clip again where the bloke changes the little clip on the window guide. Still haven't got the faintest idea how to get the door trim off!
500bhp
RE: Re: RE: Re: RE: Re: led side lights
Post by 500bhp » Thu Feb 18, 2010 9:42 pm
Whilst the Ultra 501 are fantastic, easy to fit and have no fault code issues, these http://www.ultraleds.co.uk/1157-stop-ta ... 1_132.html cause DIS problems
RS6 C5
RS6 C5, Grizzed
TVR TWIN Turbo Griff.
S8 1998 Audi Motor Show Car. Chipped & Fully Loaded
Welky
Post by Welky » Sat Feb 27, 2010 1:01 am
At the risk of being an ass, can someone talk me through the replacement process? Not quite as simple as you would expect, even though its just a bulb! How do you even get to 'the bits?'
C5 RS6 Avant. Muggle Blue, Black leather, PSS9s, Hotchkiss ARBs, Grizz's BIG brake kit, Phaeton cooling ducts.
johnny11
Post by johnny11 » Sat Feb 27, 2010 10:57 am
i put mine in last week, took around 15mins, ok you move the 2 metal clips from the back of the light so you can then pull the back of the light cover out a bit, you are a bit restricted as this only comes out a few inches, then locate the side light, i put the side light on quickly to check i was pulling the right one out. Then you have to ease you fingers to the side light bulb holder which is black plastic, then once you got hold of it just pull it until it comes out.
Welky
Post by Welky » Sat Feb 27, 2010 12:26 pm
Thanks Johnny, its getting the bulb holder out that's the pig. It turns but doesn't want to come out. Hands in bits!
johnny11
Post by johnny11 » Sat Feb 27, 2010 12:48 pm
yea it is tight but it will come out, once you got hold of it just pull it slowly out.
Welky
Post by Welky » Sat Feb 27, 2010 1:03 pm
Got it at last, and by Odin's Raven that's a fiddly job! Well worth the wounds as its a vast improvement on the old yellas. Thanks mate.
johnny11
Post by johnny11 » Sat Feb 27, 2010 1:25 pm
No probs, glad you got it sorted
rol
Post by rol » Sat Feb 27, 2010 3:38 pm
Has anyone replaced number plate bulbs with led ones?
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Sat Feb 27, 2010 5:19 pm
Yes I have albeit on a B5 RS4.
Virdee Autos ~ 07950-526592
rol
Post by rol » Sat Feb 27, 2010 6:46 pm
What`s all involved I also would like to change all interior light bulbs to led ones in my rs6 c5 I realise there are some posts on this but its still not clear to me which bulbs numbers suppliers how many etc are needed and making sure they are the correct ones so don`t come up with a fault. All help appreciated.
Thanks.
R1NGA
Post by R1NGA » Mon Mar 01, 2010 11:08 am
From my experience the car seems to tolerate the front side-lights being changed to LED, but are less so with the rears. One bulb works OK, but then you do the other side and then DIS shows an error. Modern cars just cannot hack these low-current bulbs very well (my 2006 Panda shows exactly the same symptoms) and although you can buy 'hot resistors' to put in series with the LED bulbs to get over the problem, you lose all benefit of the micro-current draw advantages that LED bulbs offer and add complexity (and heat!) into the mix....
Phil G
paul_23
Post by paul_23 » Sat Mar 06, 2010 5:13 pm
I have read the posting of how to remove the side lights, but I can't seem to get the bulb holder out - does it turn before you pull it, or is it just a straight pull out as it won't shift and I fear I will snap something....
GardinerG
Post by GardinerG » Sat Mar 06, 2010 6:07 pm
RS6Dave wrote:These are the ones I fitted about a month ago..... http://www.ultraleds.co.uk/ultimate-501 ... -1684.html
Dearer than some I've seen on ebay but no fault codes/problems and so much better than the original ones.
Dave
Same here, I use them and am pleased with the results. :thumbs:
Users browsing this forum: Bing [Bot], philS2 and 118 guests
