Secondary Air Injection System fix and diagnostics
2.7 V6 30v biturbo - 380 bhp
neckarsulm
RE: Re: RE: Re: RE: Secondary Air Injection System fix and d
Post by neckarsulm » Fri Jan 29, 2010 6:26 pm
Hektor,
Checked ETKA and not got a match for that part number
If it's at the back right hand side of the Y pipe and you have to pull it off to remove the Y pipe this is the PCV breather which looks like it's part of the dreaded spider pipe at back of head.
[just checked mine and it is]
You thus need a new spider pipe from main dealer or Virdee which is worth changing anyway though I'd pay someone :)
078 103 235 G
Which nut are you struggling with the one? I guess there's just one nut, the rest are bolts and that's on the side rather than the top, it behind a few pipes but I just slotted in a small 10mm spanner
TopBear
Post by TopBear » Fri Jan 29, 2010 6:42 pm
Can you identify the pipe from the diagram here?
http://www.vagcat.com/epc/cat/au/RS4/20 ... 9/2972882/
You'll probably need to create an account to access the diagram.
:blackrs4: B5 RS4, MRC Remap, Milltek, RS6\B7 Brakes, Black\Carbon
TopBear
Re: RE: Re: RE: Re: RE: Secondary Air Injection System fix a
Post by TopBear » Fri Jan 29, 2010 6:44 pm
HEKTOR wrote:does the inside of the y pipe become oily over time?
Yep, it's totally normal to get quite oily.
HEKTOR
Trader (Expired)
RE: Re: RE: Re: RE: Re: RE: Secondary Air Injection System f
Post by HEKTOR » Fri Jan 29, 2010 10:29 pm
neckarsulm just found out that it is the pcv but only the pipe that connects to the alloy y pipe everything else is fine. I managed to lean on the small pipe and snap it, is it possible to replace this pipe with something similar or do i need the whole thing?
And it is the small nut at the back of the pump which i cannot for the life of me get round to, if only i had smaller hands!!!!
Topbear i was worried that there was something wrong with my engine, but it is good to know that its ok. Would you recommend cleaning things since they are off?
neckarsulm
Post by neckarsulm » Sat Jan 30, 2010 1:16 pm
According to ETKA it's all one piece (see pic)
A certain Surrey specialist (not just 2.7T) had fitted my new pump and hadn't tightened that nut up which made it easy for me :shock:
HEKTOR
Trader (Expired)
Post by HEKTOR » Sat Jan 30, 2010 2:07 pm
I just need that pipe which comes out of the left hand side if the pvc the rest is in tact and so are the clips, could i replace the pipe with rubber? if so where could i get it from?
I managed to get the nut and change the pump over, everything is such a tight fit i dont think i will be changing anything again.
neckarsulm
Post by neckarsulm » Sat Jan 30, 2010 2:30 pm
Are you sure you haven't removed a turbo in error :D
According to ETKA (which is what main dealers pick their parts from) the part number you quoted doesn't exist, which is because you have to buy the whole lot as shown in pic item 51 078 103 235 G
HEKTOR
Trader (Expired)
Post by HEKTOR » Sat Jan 30, 2010 2:48 pm
Defo not a turbo, but just about everything else to get to the pump lol
They quoted me £70 for the whole lot lol i tried to say i dont need the whole lot just a small pipe that connects from the pcv to y pipe but they were having none of it, so im trying to fine a rubber pipe that will do the job and save myself some cash in the process.
Why do i have to be such an idiot when it comes to D.I.Y
HEKTOR
Trader (Expired)
Post by HEKTOR » Sat Jan 30, 2010 2:53 pm
maybe this is the part number pa6 gf 30, both numbers i have posted have came from the back of the item in question
neckarsulm
Post by neckarsulm » Sat Jan 30, 2010 4:36 pm
Trust me Hektor, maybe once upon a time that part was available separatelt but now it's not, have checked across VW Audi Seat and Skoda parts indices.
Best to fabricate something.
The same issue applies to the breather on Golf VR6 but luckily you can get the separate bit if you order it for a Sharan.
HEKTOR
Trader (Expired)
Post by HEKTOR » Sat Jan 30, 2010 4:43 pm
Nice one, i'll try and get something sorted.
cheers for the help and advice
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Sat Jan 30, 2010 6:10 pm
As said thats part of the spider pipe.
Try and improvise, if you don't fancy changing the whole lot!
They do get brittle over time with heat, etc, that's probably why it broke on you.
Virdee Autos ~ 07950-526592
HEKTOR
Trader (Expired)
Post by HEKTOR » Sat Jan 30, 2010 6:13 pm
i will try and source a small bit of silicone pipe and hopefully that will get it sorted, cheers for the help and advice.
HEKTOR
Trader (Expired)
Post by HEKTOR » Mon Feb 01, 2010 1:46 pm
Finally fixed it, i managed to re-use the clip and pcv and joined both using a bit of rubber pipe which my local garage gave to me for free, the car seems to be working fine fingers crossed, but i dont think i will be trying anything D.I.Y again.
Anyway many thanks for your help, advice and patience.
eddie
Sql_RS4
Post by Sql_RS4 » Mon Feb 01, 2010 1:47 pm
Why don't you just get rid of this whole SAI system?
